Hello,
I recently purchased an Aeotec Water Sensor Pro 7 and included it just fine with the Hubitat hub. However, when I went to attach it to a rule in the rule machine as a device it shows up but when I select the check box next to it and click update, it doesn't keep it. Also, when I've tried to go and tie to a dashboard it does this also. The location where it is mounted is the same location that I included it from and it won't show any events either with water/without water. I've excluded it and included it again as well as reset the sensor just to see if that impacted it. It's probably only 20 ft from the hub through one wall.
Any thoughts would be helpful.
Reference Items:
Hardware Version - C5
Platform Version - 2.2.8.156
