Hi John
Thanks for your answer. I enabled debug logging, see below.
dev:1752020-01-25 22:25:21.792 infoOffice - Multisensor temperature is 20.0°C
dev:1752020-01-25 22:25:21.787debugSensorMultilevelReport: SensorMultilevelReport(precision:1, scale:0, sensorType:1, sensorValue:[0, 191], size:2, scaledSensorValue:19.1)
dev:1752020-01-25 22:25:21.783 debugparse: zw device: 05, command: 3105, payload: 01 22 00 BF , isMulticast: false
dev:1752020-01-25 22:25:21.739 infoOffice - Multisensor temperature is 20.0°C
dev:1752020-01-25 22:25:21.721debugSensorMultilevelReport: SensorMultilevelReport(precision:1, scale:0, sensorType:1, sensorValue:[0, 191], size:2, scaledSensorValue:19.1)
dev:1752020-01-25 22:25:21.705 debugparse: zw device: 05, command: 3105, payload: 01 22 00 BF 1E 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 , isMulticast: true
dev:1752020-01-25 22:25:21.705 infoOffice - Multisensor humidity is 56%
dev:1752020-01-25 22:25:21.703debugSensorMultilevelReport: SensorMultilevelReport(precision:0, scale:0, sensorType:5, sensorValue:[56], size:1, scaledSensorValue:56)
dev:1752020-01-25 22:25:21.699 debugparse: zw device: 05, command: 3105, payload: 05 01 38 00 , isMulticast: false
dev:1752020-01-25 22:25:21.523 infoOffice - Multisensor illuminance is 0 Lux
dev:1752020-01-25 22:25:21.521debugSensorMultilevelReport: SensorMultilevelReport(precision:0, scale:1, sensorType:3, sensorValue:[0, 0], size:2, scaledSensorValue:0)
dev:1752020-01-25 22:25:21.491 debugparse: zw device: 05, command: 3105, payload: 03 0A 00 00 1E 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 , isMulticast: true
dev:1752020-01-25 22:25:21.482 debugparse: zw device: 05, command: 3105, payload: 03 0A 00 00 , isMulticast: false
dev:1752020-01-25 22:25:21.368 infoOffice - Multisensor battery level is 88%
dev:1752020-01-25 22:25:21.367debugBatteryReport: BatteryReport(batteryLevel:88)
dev:1752020-01-25 22:25:21.366 infoOffice - Multisensor battery level is 88%
dev:1752020-01-25 22:25:21.364debugBatteryReport: BatteryReport(batteryLevel:88)
dev:1752020-01-25 22:25:21.337 debugparse: zw device: 05, command: 8003, payload: 58 , isMulticast: false
dev:1752020-01-25 22:25:21.332 debugparse: zw device: 05, command: 8003, payload: 58 1E 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 , isMulticast: true
