Aeon Multi Sensor V6
Hub is on 2.2.8.129
What does the following mean:
Did you change drivers lately? Looks like you have a scheduled task from a driver that no longer has a matching method. If you look at the bottom of the device page you should see a scheduled task that matches.
Easiest way to clear is to temporarily change the driver to Device and push the Delete All Scheduled Jobs button, and then change the driver back.
