Aeon LED Color Bulb Refresh Behavior
I’m seeing some strange behavior in the Z-wave Aeon LED Color bulb (using generic Z-wave dimmer, since @mike.maxwell is known to be working on the correct DTH for this bulb).
Through Simple Lighting, I have three of these bulbs going on at Sunset, off at Sunrise. All three go on/off, but, one of the three still reports as on (at 90%), even though it is physically off. Dashboard shows it as on, and when I view it in the web interface, it shows as on until I refresh it, then it has the correct state.
I saw similar behavior with other embedded Z-wave devices on ST - is this some generic Z-wave plus or driver issue?
the fact that two of the three work correctly would point in my mind that the one is a little slower to respond, the 90% guy probably got asked for a report before he was done turning off…
Interesting - so, it could be individual radio performance in the bulb? I’m guessing that there is nothing really to fix this (even a Z-wave repair?)
that or maybe it’s at the end of the mesh, you can try a repair, couldn’t hurt
@mike.maxwell How’s the progress on the Aeon LED Bulb Gen 5, please? Do you have something mostly ready that I can test? I used these bulbs to “announce” various situations, the most obvious of which is “purple = Garage Door Open.” I’m using the Generic Z-Wave Dimmer too, while waiting.
Eric Maycock @ericm "announced" yesterday that he had his library of code converted to Hubitat, although he cautioned that many had not been tested.
I grabbed a copy and verified that it at least came close to working and then started "correcting" the code - I'd say almost entirely cosmetically. For instance, the raw code shows a text box for Debug Enable and I converted that to "normal" Hubitat.
It does work with some of the things I've been wanting, although at the moment, I'm seeing a problem with Capture and Restore State in RM. I have no idea how that gets implemented and thus I can't say if the Driver participates or not.
Anyway, it seems better to me that all the previous ones I've tried so here is my "adjusted" code for your colorful edification. :slight_smile:
 *  Copyright 2016 Eric Maycock
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Aeon RGBW Bulb (Advanced)
 *  Author: Eric Maycock (erocm123)
 *  Date: 2016-10-25
metadata {
	definition (name: "Aeon RGBW Bulb (Advanced) m2.02", namespace: "erocm123", author: "Eric Maycock") {
		capability "Switch Level"
		capability "Color Control"
		capability "Color Temperature"
		capability "Switch"
		capability "Refresh"
		capability "Actuator"
		capability "Sensor"
        capability "Configuration"
        capability "Health Check"
		command "reset"
		command "refresh"
        (1..6).each { n ->
			attribute "switch$n", "enum", ["on", "off"]
			command "on$n"
			command "off$n"
        fingerprint mfr: "0086", prod: "0103", model: "0062", deviceJoinName: "Aeon RGBW Bulb"
        fingerprint mfr: "0086", prod: "0103", model: "0079", deviceJoinName: "Aeon RGBW LED Strip"
        fingerprint deviceId: "0x1101", inClusters: "0x5E, 0x26, 0x33, 0x27, 0x2C, 0x2B, 0x70, 0x59, 0x85, 0x72, 0x86, 0x7A, 0x73, 0xEF, 0x5A, 0x82"
    preferences {
    	  generate_preferences(configuration_model())
        input description: "Create a custom program by modifying the settings below. This program can then be executed by using the \"custom\" button on the device page.", title: "Programs", displayDuringSetup: false, type: "paragraph", element: "paragraph"
        input "transition", "enum", title: "Transition", defaultValue: 0, displayDuringSetup: false, required: false, options: [
                0:"Smooth",
                1:"Flash",
        input "brightness", "number", title: "Brightness (Firmware 1.05)", defaultValue: 1, displayDuringSetup: false, required: false, range: "1..99"
        input "count", "number", title: "Cycle Count (0 [unlimited])", defaultValue: 0, displayDuringSetup: false, required: false, range: "0..254"
        input "speed", "enum", title: "Color Change Speed", defaultValue: 0, displayDuringSetup: false, required: false, options: [
                0:"Fast",
                1:"Medium Fast",
                2:"Medium",
                3:"Medium Slow",
                4:"Slow"]
        input "speedLevel", "number", title: "Color Residence Time (1 [fastest], 254 [slowest])", defaultValue: "0", displayDuringSetup: true, required: false, range: "0..254"
        (1..8).each { i ->
        input "color$i", "enum", title: "Color $i", displayDuringSetup: false, required: false, options: [
                1:"Red",
                2:"Orange",
                3:"Yellow",
                4:"Green",
                5:"Cyan",
                6:"Blue",
                7:"Violet",
                8:"Pink"]
	   input "debugOutput", "bool",
	   	    title: "Enable debug logging?",
	   	    defaultValue: true,
	   	    required: false
	main(["switch"])
	details(["switch", "levelSliderControl",
             "colorTempControl", "colorTempTile",
             "switch1", "switch2", "switch3",
             "switch4", "switch5", "switch6",
             "refresh", "configure", "currentFirmware" ])
* Triggered when Done button is pushed on Preference Pane
def updated()
    logging("updated() is being called")
    sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
    state.needfwUpdate = ""
    def cmds = update_needed_settings()
    sendEvent(name:"needUpdate", value: device.currentValue("needUpdate"), displayed:false, isStateChange: true)
    if (cmds != []) response(commands(cmds))
def configure() {
    logging("Configuring Device For Hubitat Use")
    def cmds = []
    if (cmds != []) commands(cmds)
def parse(description) {
	def result = null
	if (description != "updated") {
		def cmd = zwave.parse(description, [0x20: 1, 0x26: 3, 0x70: 1, 0x33:3])
		if (cmd) {
			result = zwaveEvent(cmd)
			logging("'$cmd' parsed to $result")
		} else {
			logging("Couldn't zwave.parse '$description'")
	result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
	dimmerEvents(cmd)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
	dimmerEvents(cmd)
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv3.SwitchMultilevelReport cmd) {
	//dimmerEvents(cmd)
private dimmerEvents(hubitat.zwave.Command cmd) {
	def value = (cmd.value ? "on" : "off")
	def result = [createEvent(name: "switch", value: value, descriptionText: "$device.displayName was turned $value")]
	if (cmd.value) {
		result << createEvent(name: "level", value: cmd.value, unit: "%")
    if (cmd.value == 0) toggleTiles("all")
	return result
def zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
//	response(command(zwave.switchMultilevelV1.switchMultilevelGet()))
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x31: 5, 0x30: 2, 0x84: 1, 0x70: 1])
	state.sec = 1
	if (encapsulatedCommand) {
		zwaveEvent(encapsulatedCommand)
	} else {
		log.warn "Unable to extract encapsulated cmd from $cmd"
		createEvent(descriptionText: cmd.toString())
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport cmd) {
	response(configure())
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
    if (cmd.parameterNumber == 37) {
       if (cmd.configurationValue[0] == 0) toggleTiles("all")
    } else {
       update_current_properties(cmd)
       logging("${device.displayName} parameter '${cmd.parameterNumber}' with a byte size of '${cmd.size}' is set to '${cmd.configurationValue}'")
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd){
    logging("Version Report ${cmd.toString()} ---- ${cmd.applicationVersion}.${cmd.applicationSubVersion.toString().padLeft(2, '0')}")
    state.needfwUpdate = "false"
    updateDataValue("firmware", "${cmd.applicationVersion}.${cmd.applicationSubVersion.toString().padLeft(2, '0')}")
    createEvent(name: "currentFirmware", value: "${cmd.applicationVersion}.${cmd.applicationSubVersion.toString().padLeft(2, '0')}")
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	def result = []
	def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
	log.debug "msr: $msr"
	updateDataValue("MSR", msr)
	result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
	result
def zwaveEvent(hubitat.zwave.Command cmd) {
	def linkText = device.label ?: device.name
	[linkText: linkText, descriptionText: "$linkText: $cmd", displayed: false]
private toggleTiles(value) {
   def tiles = ["switch1", "switch2", "switch3", "switch4", "switch5", "switch6"]
   tiles.each {tile ->
      if (tile != value) { sendEvent(name: tile, value: "off") }
      else { sendEvent(name:tile, value:"on"); sendEvent(name:"switch", value:"on") }
def on() {
    toggleTiles("all")
	commands([
		zwave.basicV1.basicSet(value: 0xFF),
		zwave.basicV1.basicGet(),
def off() {
    toggleTiles("all")
	commands([
		zwave.basicV1.basicSet(value: 0x00),
def setLevel(level) {
    toggleTiles("all")
	setLevel(level, 1)
def setLevel(level, duration) {
	if(level > 99) level = 99
	commands([
		zwave.switchMultilevelV3.switchMultilevelSet(value: level, dimmingDuration: duration),
	], (duration && duration < 12) ? (duration * 1000) : 3500)
def refresh() {
	commands([
        zwave.configurationV1.configurationGet(parameterNumber: 37),
        zwave.manufacturerSpecificV2.manufacturerSpecificGet()
def ping() {
    log.debug "ping()"
	refresh()
def setSaturation(percent) {
	logging("setSaturation($percent)")
	setColor(saturation: percent)
def setHue(value) {
	logging("setHue($value)")
	setColor(hue: value)
private getEnableRandomHue(){
    switch (settings.enableRandom) {
        case "0":
        return 23
        break
        case "1":
        return 52
        break
        case "2":
        return 53
        break
        case "3":
        return 20
        break
        default:
        break
private getEnableRandomSat(){
        case "0":
        return 56
        break
        case "1":
        return 19
        break
        case "2":
        return 91
        break
        case "3":
        return 80
        break
        default:
        break
def setColor(value) {
	def result = []
    def warmWhite = 0
    def coldWhite = 0
	logging("setColor: ${value}")
	if (value.hue && value.saturation) {
        logging("setting color with hue & saturation")
        def hue = (value.hue != null) ? value.hue : 13
		def saturation = (value.saturation != null) ? value.saturation : 13
		def rgb = huesatToRGB(hue as Integer, saturation as Integer)
    	if ( settings.enableRandom && value.hue == getEnableRandomHue() && value.saturation == getEnableRandomSat() ) {
            Random rand = new Random()
            int max = 100
            hue = rand.nextInt(max+1)
        else if ( value.hue == 23 && value.saturation == 56 ) {
        	def level = 255
        	if ( value.level != null ) level = value.level * 0.01 * 255
            warmWhite = level
            coldWhite = 0
            rgb[0] = 0
            rgb[1] = 0
            rgb[2] = 0
        else {
    		if ( value.hue > 5 && value.hue < 100 ) hue = value.hue - 5 else hue = 1
		result << zwave.switchColorV3.switchColorSet(red: rgb[0], green: rgb[1], blue: rgb[2], warmWhite:warmWhite, coldWhite:coldWhite)
        if(value.level != null && value.level != 1.0){
        	if(value.level > 99) value.level = 99
			result << zwave.switchMultilevelV3.switchMultilevelSet(value: value.level, dimmingDuration: 3500)
            result << zwave.switchMultilevelV3.switchMultilevelGet()
    else if (value.hex) {
		def c = value.hex.findAll(/[0-9a-fA-F]{2}/).collect { Integer.parseInt(it, 16) }
		result << zwave.switchColorV3.switchColorSet(red:c[0], green:c[1], blue:c[2], warmWhite:0, coldWhite:0)
 	result << zwave.basicV1.basicSet(value: 0xFF)
    result << zwave.basicV1.basicGet()
	if(value.hue) sendEvent(name: "hue", value: value.hue)
	if(value.hex) sendEvent(name: "color", value: value.hex)
	if(value.switch) sendEvent(name: "switch", value: value.switch)
	if(value.saturation) sendEvent(name: "saturation", value: value.saturation)
    toggleTiles("all")
	commands(result)
def setColorTemperature(percent) {
	if(percent > 99) percent = 99
	int warmValue = percent * 255 / 99
    toggleTiles("all")
    sendEvent(name: "colorTemperature", value: percent)
	command(zwave.switchColorV3.switchColorSet(red:0, green:0, blue:0, warmWhite: (warmValue > 127 ? 255 : 0), coldWhite: (warmValue < 128? 255 : 0)))
def reset() {
	logging("reset()")
	sendEvent(name: "color", value: "#ffffff")
	setColorTemperature(1)
private command(hubitat.zwave.Command cmd) {
	if (state.sec) {
		zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
	} else {
		cmd.format()
private commands(commands, delay=500) {
	delayBetween(commands.collect{ command(it) }, delay)
def rgbToHSV(red, green, blue) {
	float r = red / 255f
	float g = green / 255f
	float b = blue / 255f
	float max = [r, g, b].max()
	float delta = max - [r, g, b].min()
	def hue = 13
	def saturation = 0
	if (max && delta) {
		saturation = 100 * delta / max
		if (r == max) {
			hue = ((g - b) / delta) * 100 / 6
		} else if (g == max) {
			hue = (2 + (b - r) / delta) * 100 / 6
		} else {
			hue = (4 + (r - g) / delta) * 100 / 6
	[hue: hue, saturation: saturation, value: max * 100]
def huesatToRGB(float hue, float sat) {
	while(hue >= 100) hue -= 100
	int h = (int)(hue / 100 * 6)
	float f = hue / 100 * 6 - h
	int p = Math.round(255 * (1 - (sat / 100)))
	int q = Math.round(255 * (1 - (sat / 100) * f))
	int t = Math.round(255 * (1 - (sat / 100) * (1 - f)))
	switch (h) {
		case 0: return [255, t, p]
		case 1: return [q, 255, p]
		case 2: return [p, 255, t]
		case 3: return [p, q, 255]
		case 4: return [t, p, 255]
		case 5: return [255, p, q]
def on1() {
    logging("on1()")
    toggleTiles("switch1")
    def cmds = []
    if (device.currentValue("currentFirmware") == null || device.currentValue("currentFirmware") != "1.05") {
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 16781342, parameterNumber: 37, size: 4)
    } else {
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 50332416, parameterNumber: 38, size: 4)
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(157483073 , 4), parameterNumber: 37, size: 4)
    cmds << zwave.basicV1.basicGet()
	commands(cmds)
def on2() {
    logging("on2()")
    toggleTiles("switch2")
    def cmds = []
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 1090551813, parameterNumber: 37, size: 4)
    } else {
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 2560, parameterNumber: 38, size: 4)
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(1097007169, 4), parameterNumber: 37, size: 4)
	commands(cmds)
def on3() {
    logging("on3()")
    toggleTiles("switch3")
    def cmds = []
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 50335754, parameterNumber: 37, size: 4)
    } else {
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(191037440 , 4), parameterNumber: 37, size: 4)
	commands(cmds)
def on4() {
    logging("on4()")
    toggleTiles("switch4")
    def cmds = []
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 1633771873, parameterNumber: 38, size: 4)
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 1113784321, parameterNumber: 37, size: 4)
    } else {
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(256, 4), parameterNumber: 38, size: 4)
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(369098752, 4), parameterNumber: 39, size: 4)
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(1244790848, 4), parameterNumber: 37, size: 4)
	commands(cmds)
def on5() {
    logging("on5()")
    toggleTiles("switch5")
    def cmds = []
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 65, parameterNumber: 38, size: 4)
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 1107300372, parameterNumber: 37, size: 4)
    } else {
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(768, 4), parameterNumber: 38, size: 4)
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(335544320, 4), parameterNumber: 39, size: 4)
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(1244790784, 4), parameterNumber: 37, size: 4)
	commands(cmds)
def on6() {
    logging("on6()")
    toggleTiles("switch6")
    def cmds = []
    if (device.currentValue("currentFirmware") == null || device.currentValue("currentFirmware") != "1.04") {
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(calculateParameter(38), 4), parameterNumber: 38, size: 4)
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: calculateParameter(37), parameterNumber: 37, size: 4)
    } else {
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(calculateParameter(39), 4), parameterNumber: 39, size: 4)
        cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(calculateParameter(37), 4), parameterNumber: 37, size: 4)
	commands(cmds)
def offCmd() {
    logging("offCmd()")
    def cmds = []
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 0, parameterNumber: 37, size: 4)
        cmds << zwave.configurationV1.configurationGet(parameterNumber: 37)
    } else {
        cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 2, parameterNumber: 36, size: 1)
    commands(cmds)
def off1() { offCmd() }
def off2() { offCmd() }
def off3() { offCmd() }
def off4() { offCmd() }
def off5() { offCmd() }
def off6() { offCmd() }
private calculateParameter(number) {
   long value = 0
   switch (number){
      case 37:
      if (device.currentValue("currentFirmware") == null || device.currentValue("currentFirmware") == "1.04"){
         value += settings.transition ? settings.transition.toLong() * 1073741824 : 0
         value += 33554432 // Custom Mode
         value += settings.count ? (settings.count.toLong() * 65536) : 0
         value += settings.speed ? (settings.speed.toLong() * 16 * 256) : 0
         value += settings.speedLevel ? settings.speedLevel.toLong() : 0
      } else {
         value += 134217728 // Allow smooth adjustable speed
         value += settings.brightness ? (settings.brightness.toLong() * 65536) : 0
         value += settings.count ? (settings.count.toLong() * 256) : 0
         value += settings.speed ? (2 * 32) : 0
      break
      case 38:
         value += settings.color1 ? (settings.color1.toLong() * 1) : 0
         value += settings.color2 ? (settings.color2.toLong() * 16) : 0
         value += settings.color3 ? (settings.color3.toLong() * 256) : 0
         value += settings.color4 ? (settings.color4.toLong() * 4096) : 0
         value += settings.color5 ? (settings.color5.toLong() * 65536) : 0
         value += settings.color6 ? (settings.color6.toLong() * 1048576) : 0
         value += settings.color7 ? (settings.color7.toLong() * 16777216) : 0
         value += settings.color8 ? (settings.color8.toLong() * 268435456) : 0
      } else {
         value += settings.transition == "1" ? 0 : (settings.speed.toLong() * 2 * 16777216) // Speed from off to on
         value += settings.transition == "1" ? 0 : (settings.speed.toLong() * 2 * 65536) // Speed from on to off
         value += settings.speedLevel ? (settings.speedLevel.toLong() * 256) : 5 // Pause time at on
         value += 0 // Pause time at off
      break
      case 39:
         value += settings.color8 ? (settings.color8.toLong() * 1) : 0
         value += settings.color7 ? (settings.color7.toLong() * 16) : 0
         value += settings.color6 ? (settings.color6.toLong() * 256) : 0
         value += settings.color5 ? (settings.color5.toLong() * 4096) : 0
         value += settings.color4 ? (settings.color4.toLong() * 65536) : 0
         value += settings.color3 ? (settings.color3.toLong() * 1048576) : 0
         value += settings.color2 ? (settings.color2.toLong() * 16777216) : 0
         value += settings.color1 ? (settings.color1.toLong() * 268435456) : 0
      break
    return value
def generate_preferences(configuration_model)
    def configuration = new XmlSlurper().parseText(configuration_model)
    configuration.Value.each
        switch(it.@type)
            case ["byte","short","four"]:
                input "${it.@index}", "number",
                    title:"${it.@label}\n" + "${it.Help}",
                    range: "${it.@min}..${it.@max}",
                    defaultValue: "${it.@value}",
                    displayDuringSetup: "${it.@displayDuringSetup}"
            break
            case "list":
                def items = []
                it.Item.each { items << ["${it.@value}":"${it.@label}"] }
                input "${it.@index}", "enum",
                    displayDuringSetup: "${it.@displayDuringSetup}",
                    options: items
            break
            case "decimal":
               input "${it.@index}", "decimal",
            break
            case "boolean":
               input "${it.@index}", "boolean",
                    title: it.@label != "" ? "${it.@label}\n" + "${it.Help}" : "" + "${it.Help}",
            break
def update_current_properties(cmd)
    def currentProperties = state.currentProperties ?: [:]
    currentProperties."${cmd.parameterNumber}" = cmd.configurationValue
    if (settings."${cmd.parameterNumber}" != null)
        if (convertParam(cmd.parameterNumber, settings."${cmd.parameterNumber}") == cmd2Integer(cmd.configurationValue))
            sendEvent(name:"needUpdate", value:"NO", displayed:false, isStateChange: true)
        else
            sendEvent(name:"needUpdate", value:"YES", displayed:false, isStateChange: true)
    state.currentProperties = currentProperties
def update_needed_settings()
    def cmds = []
    def configuration = new XmlSlurper().parseText(configuration_model())
    def isUpdateNeeded = "NO"
    if(!state.needfwUpdate || state.needfwUpdate == ""){
       logging("Requesting device firmware version")
       cmds << zwave.versionV1.versionGet()
        if ("${it.@setting_type}" == "zwave"){
            if (currentProperties."${it.@index}" == null)
                if (device.currentValue("currentFirmware") == null || "${it.@fw}".indexOf(device.currentValue("currentFirmware")) >= 0){
                    isUpdateNeeded = "YES"
                    logging("Current value of parameter ${it.@index} is unknown")
                    cmds << zwave.configurationV1.configurationGet(parameterNumber: it.@index.toInteger())
            else if ((settings."${it.@index}" != null || "${it.@type}" == "hidden") && cmd2Integer(currentProperties."${it.@index}") != convertParam(it.@index.toInteger(), settings."${it.@index}"? settings."${it.@index}" : "${it.@value}"))
                logging("Parameter ${it.@index} will be updated to " + convertParam(it.@index.toInteger(), settings."${it.@index}"? settings."${it.@index}" : "${it.@value}"))
                def convertedConfigurationValue = convertParam(it.@index.toInteger(), settings."${it.@index}"? settings."${it.@index}" : "${it.@value}")
                cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(convertedConfigurationValue, it.@byteSize.toInteger()), parameterNumber: it.@index.toInteger(), size: it.@byteSize.toInteger())
    sendEvent(name:"needUpdate", value: isUpdateNeeded, displayed:false, isStateChange: true)
    return cmds
def convertParam(number, value) {
    def parValue
	switch (number){
    	case 28:
            parValue = (value == "true" ? 1 : 0)
            parValue += (settings."fc_2" == "true" ? 2 : 0)
            parValue += (settings."fc_3" == "true" ? 4 : 0)
            parValue += (settings."fc_4" == "true" ? 8 : 0)
        break
        case 29:
            parValue += (settings."sc_2" == "true" ? 2 : 0)
            parValue += (settings."sc_3" == "true" ? 4 : 0)
            parValue += (settings."sc_4" == "true" ? 8 : 0)
        break
        default:
        	parValue = value
        break
    return parValue.toInteger()
private def logging(message) {
	if (settings?.debugOutput || settings?.debugOutput == null) log.debug "$message"
* Convert 1 and 2 bytes values to integer
def cmd2Integer(array) {
switch(array.size()) {
	case 1:
		array[0]
    break
	case 2:
    	((array[0] & 0xFF) << 8) | (array[1] & 0xFF)
    break
    case 3:
    	((array[0] & 0xFF) << 16) | ((array[1] & 0xFF) << 8) | (array[2] & 0xFF)
    break
	case 4:
    	((array[0] & 0xFF) << 24) | ((array[1] & 0xFF) << 16) | ((array[2] & 0xFF) << 8) | (array[3] & 0xFF)
	break
def integer2Cmd(value, size) {
	switch(size) {
	case 1:
		[value]
    break
	case 2:
    	def short value1   = value & 0xFF
        def short value2 = (value >> 8) & 0xFF
        [value2, value1]
    break
    case 3:
        def short value3 = (value >> 16) & 0xFF
        [value3, value2, value1]
    break
	case 4:
        def short value4 = (value >> 24) & 0xFF
		[value4, value3, value2, value1]
	break
def configuration_model()
<configuration>
  <Value type="list" byteSize="1" index="20" label="Default State (Firmware v1.05)" min="0" max="2" value="0" setting_type="zwave" fw="1.05">
    <Help>
Default state of the bulb when power is applied.
Range: 0~2
Default: 0 (Previous)
    </Help>
    <Item label="Previous" value="0" />
    <Item label="Always On" value="1" />
    <Item label="Always Off" value="2" />
  </Value>
  <Value type="disabled" byteSize="1" index="32" label="Color Report" min="0" max="1" value="0" setting_type="zwave" fw="1.05">
    <Help>
Enable or disable the sending of a report when the bulb color is changed.
Range: 0~1
Default: 0 (Disabled)
    </Help>
    <Item label="Disable" value="0" />
    <Item label="Enable" value="1" />
  </Value>
    <Value type="list" byteSize="1" index="34" label="External Switch" min="0" max="1" value="0" setting_type="zwave" fw="1.04,1.05">
    <Help>
Enable or disable manually toggle the LED bulb ON and OFF using an external switch.
Range: 0~1
    </Help>
  </Value>
  <Value type="disabled" byteSize="1" index="80" label="Status Report" min="0" max="2" value="2" setting_type="zwave" fw="1.04,1.05">
    <Help>
Enable or disable the sending of a report when the state of the bulb is changed.
Range: 0~2
Default: 2 (Basic CC Report)
    </Help>
    <Item label="Hail CC" value="1" />
    <Item label="Basic CC Report" value="2" />
  </Value>
    <Value type="list" byteSize="1" index="112" label="Dimmer Mode (Firmware v1.05)" min="0" max="3" value="0" setting_type="zwave" fw="1.04,1.05">
    <Help>
Range: 0~3
Default: 0 (Parabolic)
    </Help>
    <Item label="Parabolic Curve" value="0" />
    <Item label="Index Curve" value="1" />
    <Item label="(Parabolic + Index)/2" value="2" />
    <Item label="Linear" value="3" />
  </Value>
  <Value type="list" index="enableRandom" label="Enable Random Function" value="false" setting_type="preference" fw="1.04,1.05">
    <Help>
If this option is enabled, using the selected color preset in SmartApps such as Smart Lighting will result in a random color.
    </Help>
    <Item label="Soft White - Default" value="0" />
    <Item label="White - Concentrate" value="1" />
    <Item label="Daylight - Energize" value="2" />
    <Item label="Warm White - Relax" value="3" />
  </Value>
</configuration>
Thanks for this - I did just try it out, and, I'm seeing some inconsistent results using the color presets. For example, if I set color 1 to 'Red', and then turn it on, it seems to work, but, if I set color 2 to 'blue' then turn that on, I get green.
I haven't dug into it yet, but I'm assuming something not being reinitialized, resulting in a color mix. I'll see if I can dig into it more later.
