My honeywell t6 pro has been running great for the last year and a half and now on 9-28-26 something has broken the app. or at least the dashboard is stuck on my nighttime setting of 70 and it shows the unit is running, but the unit is still operating properly and following the app settings to drop the temp at night and raise the temp in the morning.
com.hubitat.app.exception.LimitExceededException: Device 912 generates excessive hub load on line 410 (method parse)
Also i am running the bcopeland driver. I will attach screenshots of more details. let me know what else is needed to figure this out. Thanks in advance for any help.
nine are working but i only hit it every 10 minutes (two locations). every two minutes has always been too much and honeywell will cut you off as you are seeing.
you could try re-doing the honeywell login and authorization.
Mine loses connection once in a while. I find out when my wife complains lol. I just remove it from the wall socket, count to 2 and plug it back in. I am not sure why it loses connection.
