Just purchased a pair of Aduro Eria smart light bulbs A19 - Tunable White & Multi-Color. I have added them to my C-8 hub, however, when I go into the details of the bulbs I do not have any choices to set the color. Is there some special driver or something I need?
I'm going to guess it didn't select the right driver automatically. I'd try "Generic Zigbee RGBW Bulb" to start:
(Also, if you feel so inclined: if the driver is "Device" now and you run the"Get Info" command, you should also see a "fingerprint" entry output in Logs. If the above driver works, sharing that log entry here could be helpful so it can get added to this driver -- avoiding this issue in the future.)
