ADT Command status possible?
I'm trying to see if there is a way to get the alarm armed/disarmed status of my ADT Command system into Hubitat so that I could use it for some automations and mode changes.
ADT is pretty locked down with their integrations. Eventually I will move to a more open alarm platform, but I have over a year left on my ADT contract so I'm hoping for a workaround now.
I have considered getting a HomeSeer HS-FS100-L Z-Wave Plus Indicator Light Sensor to monitor the green and red led on the control panel tablet, but it seems a little clunky and ugly, and not sure if it would even work.
Is there a way to scrape the user login page at control.adt.com for the armed status? I have no programming experience so I'm not sure what this entails or if it's even possible.
Or, I'm open to any other ideas I have not thought of. Thanks.
ADT Pulse can add Z-Wave relays as "switches", and then switch them on or off through Automations.
I have two ("AWAY" and "STAY"), and attach those relays' contacts to Konnected inputs.
I forgot ADT Command DOES have a zwave radio. I may have to do that, as it may be the cleanest way. I use ADT for the alarm only, so I'll have to find out if they will charge me monthly for automations. Nothing shows up in the app, I'm guessing they will want to charge extra for that.
Thanks.
