Administration of just one hub rather than two?
Hi.
I currently have a C8 and a C7 that function independently to cover a largish plot. I tried using one device but even with extenders the radio signal from the C8 (with ext. antennae) is insufficient for reliable cover. Consequently I maintain 2 hubs , 2 dashboards etc.
I am not sure whether I am missing something quite fundamental here but seeing as I have ethernet between the 2 hubs is there not a more effective way of consolidating onto a single hub? I haven't done anything with meshing but if the 2 hubs were meshed (and I would probably upgrade the C7) will that successfully use the wired ethernet?
Or is there simply a way to have a wired extender to re-broadcast the Z Wave radio?
I would just very much like to administer a single HA instance whether that's across 2 physical devices or one.
Appreciate any suggestions.
If I understand correctly, you are trying to have the hubs "talk" to each other. What I do is define one hub as the Main hub that has both devices and all the rules, and the other that only has devices. The Secondary hub then shares the devices with the Main hub via Hub Mesh. Then all the devices are available to the main hub, where the rules can then have access to all the devices. If you use dashboards, they can live on the Main hub, as all devices are again all accessible. You can also use either hub for any external (internet) connections. You still have to manage each hub separately, but it is not as bad as it sounds. Since all automations are on the Main hub, management is pretty straightforward.
Hi.
Yes, I think that is effectively what I need to do - i.e. mesh two hubs (via ethernet presumably) but ONLY meshing (all?) the Z Wave devices on both.
And yes, that would ever only seem to require one Dashboard whereas at the moment I need to operate a dashboard on each hub.
If you can just confirm the hubs mesh over ethernet (not wireless) then that seems to be the obvious route to use.
Thank you for your help.
This might answer most of your questions:
Hi. It certainly looks like the answer!
I only recently linked up the outbuilding where the second hub is situated so meshing now viable.
Thanks for bringing this to my attention.
