Here's a complete functional rule that does what you went - the CT is raised or lowered in steps of 300, when button 2 or button 4 of a Pico remote is pushed.
If you want to import it, you can use the JSON pasted below.
Pico CT Controller
{"deviceReplacements":{"4654":{"deviceName":"Guest Nightstand on HubitatM","deviceLabel":"Guest Nightstand","deviceTypeName":"Group Bulb Dimmer-2.1","deviceTypeNamespace":"hubitat"},"22":{"deviceName":"13","deviceLabel":"Guest Bedroom Pico","deviceTypeName":"Lutron Pico","deviceTypeNamespace":"hubitat"}},"appReplacements":{"5784":{"appTypeName":"Rule-5.1","appTypeNamespace":"hubitat","appType":"sys","appName":"Rule-5.1","appLabel":"Pico CT Controller","parentAppInstalledAppId":"5523","parentAppTypeName":"Rule Machine","parentAppTypeNamespace":"hubitat","parentAppName":"Rule Machine","parentAppLabel":"Rule Machine","childApps":{},"singleInstance":false}},"appData":{"5784":{"state":{"parens":{"1":0},"actionDone":true,"ndx":8,"dateFormat":"yyyy-MM-dd","installedRules":[],"nestedBlock":[],"clonedName":"Pico CT Controller","oldConst2":300,"tCustomAttrType.1":"NUMBER","selectActionsParams":{"label":"Pico CT Controller"},"editCondIf":null,"waitDone":{},"stopOnST":false,"usesTime":false,"nestedIf":[],"inIf":null,"trigCustoms":[],"repeating":null,"capabDone":true,"skipping":false,"lastEvtName":"Guest Bedroom Pico","locationBlocked":[],"pbFixed":true,"inRepIf":null,"ruleNdx":2,"actionList":["1","3","4","11","5","6","7","8","9","10"],"firstR":{"1":false},"timeTriggers":[],"locVars":{"CT":{"attribute":null,"type":"Number","value":3000,"deviceId":null}},"allVarsO":["CT"],"actLabelIndent":"","varSettingsUpdated":true,"certainTimes":[],"allVarsS":[],"allVarsT":[],"oldConst":null,"prevState":{"CT":5300,"PB":"true","22:pushed":4},"blockIf":false,"eval":{"1":[3]},"lastEvtText":"Guest Bedroom Pico button 4 was pushed [physical]","capabstrue":{"1":"Guest Bedroom Pico button 2 pushed","2":"Guest Bedroom Pico button 4 pushed"},"installedCapabs":["Configuration","RelativeHumidityMeasurement","ColorMode","HealthCheck","Initialize","PowerSource","SpeechSynthesis","Momentary","DoubleTapableButton","Light","TamperAlert","Battery","Valve","CarbonMonoxideDetector","ZwMultichannel","PresenceSensor","ColorControl","SignalStrength","Polling","ChangeLevel","PowerMeter","Switch","IlluminanceMeasurement","Tone","Bulb","Sensor","WaterSensor","EnergyMeter","ThreeAxis","VoltageMeasurement","ContactSensor","Notification","Refresh","ReleasableButton","ColorTemperature","SwitchLevel","HoldableButton","MotionSensor","DoorControl","Outlet","Telnet","UltravioletIndex","Actuator","Thermostat","AudioVolume","LockCodes","PressureMeasurement","PushableButton","GarageDoorControl","Lock","TemperatureMeasurement","AccelerationSensor","Alarm","SmokeDetector","Chime"],"nestedSkipAll":[],"skipType":"if","lastEvtDate":"2022-08-01","nestedInIf":[],"actions":{"11":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\\t","rule":null,"label":"\\tIF (Variable CT<span style='color:black'>(3000)</span> > 9000<span style='color:orange'> FALSE</span>) Set CT to 1500\\n","cond":7},"1":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"","rule":null,"label":"Set CT to Guest Nightstand colorTemperature<span style='color:black'>(3500)</span>\\n","cond":0},"3":{"wait":null,"delay":"","modes":{},"method":"getIfThen","indent":"","rule":1,"label":"IF (Last Event Device pushed = 2.0<span style='color:orange'>(F)</span><span style='color:orange'> [FALSE]</span>) THEN\\n","cond":0},"4":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\\t","rule":null,"label":"\\tSet CT to (CT<span style='color:black'>(3000)</span> + 300)\\n","cond":0},"5":{"wait":null,"delay":"","modes":{},"method":"getSetColorTemp","indent":"\\t","rule":null,"label":"\\tColor Temperature: Guest Nightstand: CT<span style='color:black'>(3000)</span> -> Level: 100\\n","cond":0},"6":{"wait":null,"delay":"","modes":{},"method":"getElse","indent":"\\t","rule":null,"label":"ELSE\\n","cond":0},"7":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\\t","rule":null,"label":"\\tSet CT to (CT<span style='color:black'>(3000)</span> - 300)\\n","cond":0},"8":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\\t","rule":null,"label":"\\tIF (Variable CT<span style='color:black'>(3000)</span> < 1500<span style='color:orange'> FALSE</span>) Set CT to 9000\\n","cond":6},"9":{"wait":null,"delay":"","modes":{},"method":"getSetColorTemp","indent":"\\t","rule":null,"label":"\\tColor Temperature: Guest Nightstand: CT<span style='color:black'>(3000)</span> -> Level: 100\\n","cond":0},"10":{"wait":null,"delay":"","modes":{},"method":"getEndIf","indent":"","rule":null,"label":"END-IF\\n","cond":0}},"usesDate":false,"actNdx":12,"lastEvtValue":"4","allVarsGT":[],"installed":true,"waitEvents":[],"private":"true","waitNdx":{},"rCustomAttrType_3":"NUMBER","allVars":{"CT":{"attribute":null,"type":"Number","value":3000,"deviceId":null}},"simpleCond":false,"changedValues":true,"nestedRepIf":[],"lastEvtTime":"19:30","condOper":"cond","nestedElse":[],"allVarsI":["CT"],"formerState":"CT","varTriggersFixed":true,"skipAll":null,"needWaitCancel":false,"cutAction":[],"allVarsD":["CT"],"broken":false,"stopped":false,"rulesList":[],"nestedLabel":[],"oldInputAct":true,"inputAct":true,"lastEvtDevId":"22","lv_CT":{"name":"CT","attribute":null,"type":"integer","value":5300,"deviceId":null},"waitCondNdx":1,"token":0,"hasElse":null,"capabsfalse":{"3":"Last Event Device pushed = 2.0","6":"Variable CT<span style='color:black'>(3000)</span> < 1500","7":"Variable CT<span style='color:black'>(3000)</span> > 9000"},"stPrimed":true,"timeTriggersW":{},"allLocalVars":{"CT":{"attribute":null,"type":"integer","value":3000,"deviceId":null}},"varSettingsOld":{},"timeFormat":"HH:mm","olddValues":true,"needWaitDone":false},"appSettings":[{"deviceList":null,"multiple":true,"name":"copyAct","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"actSubType.6","type":"enum","value":"getElse"},{"deviceList":null,"multiple":false,"name":"butEndIf","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"actSubType.7","type":"enum","value":"getSetVariable"},{"deviceList":null,"multiple":false,"name":"uVar3.9","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"actSubType.8","type":"enum","value":"getSetVariable"},{"deviceList":null,"multiple":true,"name":"disableAct","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"actSubType.9","type":"enum","value":"getSetColorTemp"},{"deviceList":null,"multiple":false,"name":"cond","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"uVar3.5","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"varType","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"actSubType.1","type":"enum","value":"getSetVariable"},{"deviceList":null,"multiple":false,"name":"tstate1","type":"enum","value":"pushed"},{"deviceList":null,"multiple":false,"name":"tstate2","type":"enum","value":"pushed"},{"deviceList":null,"multiple":false,"name":"actSubType.3","type":"enum","value":"getIfThen"},{"deviceList":null,"multiple":false,"name":"actSubType.4","type":"enum","value":"getSetVariable"},{"deviceList":null,"multiple":false,"name":"butElse","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"actSubType.5","type":"enum","value":"getSetColorTemp"},{"deviceList":null,"multiple":false,"name":"xVarV.11","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"actType.1","type":"enum","value":"modeActs"},{"deviceList":null,"multiple":false,"name":"editToken","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"uVar.4","type":"bool","value":"true"},{"deviceList":null,"multiple":false,"name":"xVar_7","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"uVar.5","type":"bool","value":"true"},{"deviceList":null,"multiple":false,"name":"xVar_6","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"hbVar","type":"text","value":""},{"deviceList":null,"multiple":false,"name":"useCond.2","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"uVar.9","type":"bool","value":"true"},{"deviceList":{"4654":"Guest Nightstand"},"multiple":false,"name":"customDev.1","type":"capability.*","value":null},{"deviceList":null,"multiple":false,"name":"delayAct.7","type":"enum","value":"none"},{"deviceList":null,"multiple":false,"name":"editGV~CT","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"delayAct.8","type":"enum","value":"none"},{"deviceList":null,"multiple":false,"name":"delayAct.9","type":"enum","value":"none"},{"deviceList":null,"multiple":false,"name":"xVar4.4","type":"enum","value":"(constant)"},{"deviceList":null,"multiple":false,"name":"useCond.8","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"valMathOp.4","type":"enum","value":"+"},{"deviceList":null,"multiple":false,"name":"xVar.9","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"valMathOp.7","type":"enum","value":"-"},{"deviceList":null,"multiple":false,"name":"xVar4.7","type":"enum","value":"(constant)"},{"deviceList":null,"multiple":false,"name":"actType.3","type":"enum","value":"condActs"},{"deviceList":null,"multiple":true,"name":"logging","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"editCond","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"xVar.5","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"delayAct.1","type":"enum","value":"none"},{"deviceList":null,"multiple":false,"name":"xVar.4","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"actType.5","type":"enum","value":"dimmerActs"},{"deviceList":null,"multiple":false,"name":"actType.4","type":"enum","value":"modeActs"},{"deviceList":null,"multiple":false,"name":"actType.7","type":"enum","value":"modeActs"},{"deviceList":null,"multiple":false,"name":"delayAct.4","type":"enum","value":"none"},{"deviceList":null,"multiple":false,"name":"actType.6","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"updateRule","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"delayAct.5","type":"enum","value":"none"},{"deviceList":null,"multiple":false,"name":"actType.9","type":"enum","value":"dimmerActs"},{"deviceList":null,"multiple":false,"name":"hasRule","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"actType.8","type":"enum","value":"modeActs"},{"deviceList":null,"multiple":false,"name":"cancelGV","type":"button","value":""},{"deviceList":{"22":"Guest Bedroom Pico"},"multiple":false,"name":"rDev_3","type":"capability.*","value":null},{"deviceList":null,"multiple":false,"name":"rCustomAttr_3","type":"enum","value":"pushed"},{"deviceList":null,"multiple":false,"name":"uVar2.5","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"uVar2.4","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"tCustomAttr.1","type":"enum","value":"colorTemperature"},{"deviceList":null,"multiple":false,"name":"uVar2.9","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"pointless","type":"button","value":""},{"deviceList":null,"multiple":true,"name":"cutAct","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"valConst2.7","type":"number","value":"300"},{"deviceList":null,"multiple":false,"name":"valConst2.4","type":"number","value":"300"},{"deviceList":null,"multiple":false,"name":"refresh","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"xVar3.4","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"moreVar","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"ctFade.5","type":"number","value":""},{"deviceList":null,"multiple":false,"name":"xVar3.7","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"ctFade.9","type":"number","value":""},{"deviceList":null,"multiple":true,"name":"deleteAct","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"ctLevel.4","type":"number","value":""},{"deviceList":null,"multiple":false,"name":"oper","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"ctLevel.5","type":"number","value":"100"},{"deviceList":null,"multiple":false,"name":"ctLevel.9","type":"number","value":"100"},{"deviceList":null,"multiple":false,"name":"tCapab1","type":"enum","value":"Button"},{"deviceList":null,"multiple":false,"name":"isVar_7","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"tCapab2","type":"enum","value":"Button"},{"deviceList":null,"multiple":false,"name":"isVar_6","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"actionDone","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"isVar_3","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"actSubType.10","type":"enum","value":"getEndIf"},{"deviceList":null,"multiple":false,"name":"tCapab3","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"actSubType.11","type":"enum","value":"getSetVariable"},{"deviceList":null,"multiple":false,"name":"xVarV.7","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"xVarV.8","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"valNumber.11","type":"number","value":"1500"},{"deviceList":null,"multiple":false,"name":"useST","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"xVarV.1","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"valNumber.8","type":"number","value":"9000"},{"deviceList":null,"multiple":false,"name":"xVarV.4","type":"enum","value":"CT"},{"deviceList":null,"multiple":false,"name":"deleteGV~CT","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"refreshActions","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"dValues","type":"bool","value":"true"},{"deviceList":null,"multiple":false,"name":"ButtontDev2","type":"number","value":"4"},{"deviceList":null,"multiple":false,"name":"ButtontDev1","type":"number","value":"2"},{"deviceList":null,"multiple":false,"name":"hasAll","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"cancelCapab","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"RelrDev_3","type":"enum","value":"="},{"deviceList":null,"multiple":false,"name":"ctL.4","type":"number","value":""},{"deviceList":null,"multiple":false,"name":"ctL.5","type":"number","value":""},{"deviceList":null,"multiple":false,"name":"numOp.7","type":"enum","value":"variable math"},{"deviceList":null,"multiple":false,"name":"RelrDev_6","type":"enum","value":"<"},{"deviceList":null,"multiple":false,"name":"numOp.8","type":"enum","value":"number"},{"deviceList":null,"multiple":false,"name":"RelrDev_7","type":"enum","value":">"},{"deviceList":null,"multiple":false,"name":"ctL.9","type":"number","value":""},{"deviceList":null,"multiple":false,"name":"numOp.1","type":"enum","value":"device attribute"},{"deviceList":null,"multiple":false,"name":"origLabel","type":"text","value":"Pico CT Controller"},{"deviceList":null,"multiple":false,"name":"eraseRule","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"numOp.4","type":"enum","value":"variable math"},{"deviceList":null,"multiple":false,"name":"delayAct.11","type":"enum","value":"none"},{"deviceList":null,"multiple":false,"name":"delete","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"actType.10","type":"enum","value":""},{"deviceList":{"22":"Guest Bedroom Pico"},"multiple":true,"name":"tDev2","type":"capability.pushableButton","value":null},{"deviceList":{"4654":"Guest Nightstand"},"multiple":true,"name":"ct.9","type":"capability.colorTemperature","value":null},{"deviceList":{"22":"Guest Bedroom Pico"},"multiple":true,"name":"tDev1","type":"capability.pushableButton","value":null},{"deviceList":null,"multiple":false,"name":"actType.11","type":"enum","value":"modeActs"},{"deviceList":{"4654":"Guest Nightstand"},"multiple":true,"name":"ct.5","type":"capability.colorTemperature","value":null},{"deviceList":null,"multiple":false,"name":"actionCancel","type":"button","value":""},{"deviceList":{"4654":"Guest Nightstand"},"multiple":true,"name":"ct.4","type":"capability.colorTemperature","value":null},{"deviceList":null,"multiple":false,"name":"numOp.11","type":"enum","value":"number"},{"deviceList":null,"multiple":false,"name":"state_7","type":"number","value":"9000"},{"deviceList":null,"multiple":false,"name":"comments","type":"textarea","value":""},{"deviceList":null,"multiple":false,"name":"state_6","type":"number","value":"1500"},{"deviceList":null,"multiple":false,"name":"useCond.11","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"state_3","type":"decimal","value":"2"},{"deviceList":null,"multiple":false,"name":"rCapab_3","type":"enum","value":"Last Event Device"},{"deviceList":null,"multiple":false,"name":"not6","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"varValue","type":"number","value":null},{"deviceList":null,"multiple":false,"name":"not3","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"not7","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"rCapab_7","type":"enum","value":"Variable"},{"deviceList":null,"multiple":false,"name":"rCapab_6","type":"enum","value":"Variable"},{"deviceList":null,"multiple":false,"name":"actType.12","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"insertAct","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"editAct","type":"enum","value":""}],"subscriptions":[{"handler":"allHandlerX","name":"pushed.2","type":"DEVICE","typeId":22,"typeName":"Guest Bedroom Pico","filter":"true"},{"handler":"allHandlerX","name":"pushed.4","type":"DEVICE","typeId":22,"typeName":"Guest Bedroom Pico","filter":"true"}]}}}
