Adding values to show total
#1
Hello guys,
One question - it is possible in HE Dashboard to add one value to another an show total value ?
I have few devices which shows power consumption and counting total consumption of the room will be nice.
(all devices can show power attribute on tile)
#2
Yes, you do this by putting the value you want to display in a Global Variable in Rule Machine. Then you can use a Connector from RM, and use that device in a Decimal Variable tile in the Dashboard. Give the GV an appropriate name, like Total Consumption, and that will show up as the title of the tile. You can do math in a rule to calculate the value to put in the variable.
See this post:
#3
Thanks, I'll check it out.
