Added new hub variable
I added a new hub variable and defined it as type Boolean and set as False. Then I created a Button Controller so that when a button is pressed, it turns the variable True. This all worked. I then went back into Settings/Hub Variables and clicked on the true tag next to this new variable. I got the following error:
In the logs is this message:
Now when I try to get into the Hub Variable screen, I get the Unexpected Error and log entry. How can I fix this, besides a restore from backup?
A hub reboot with a database rebuild didn't work (didn't think it would.)
Not sure I can help, but it may be useful for others to know the platform version you are running. I'm having trouble reproducing it on the latest beta release.
What was your Hub Variable called?
Restore from backup might work. But better would be if you sent me some stuff so I can see what's going on. I'll send you a PM.
What build are you on, and what was the variable name?
Bruce got me fixed up. Thanks again, @bravenel !
