Add Trusted Root to hub store
I have my own CA for home. I using rule machine to make some post to my NVR which has a cert from my CA. But it looks like the hubitat is not trusting the cert as when I make the same post via http it works fine.
Is there a way to add my root cert to the hubs cert store?
go to http://your.hubs.ip.here/hub/advanced/certificate
Thanks, but all that does is allow you to add an SSL CERT for habitat itself. This does not allow you to add a route certificate in the trusted store
