Add capability "ChangeLevel" to Generic Z-Wave Shades
Hi Hubitat devs,
I was trying to add button controller to control shades. Without the ChangeLevel capability from Generic Z-Wave Shades driver, I'm unable to program a button hold for raising/lowering shades and button release for stop(). Well, I guess I could make the up button hold to issue a set level command to 100 or down button hold to issue a set level command to 0. That just seems hacky. It's better to have the driver support ChangeLevel capability natively and use the z-wave switchMultilevelStartLevelChange and switchMultilevelStopLevelChange API respectively.
The driver for Generic Z-Wave Shades is close sourced. Could the Hubitat dev add ChangeLevel capability to the driver? It should be very trivial amount of work.
borrowing from https://github.com/hubitat/HubitatPublic/blob/master/examples/drivers/genericZWaveCentralSceneDimmer.groovy:
String startLevelChange(direction){
    Integer upDown = direction == "down" ? 1 : 0
    return secure(zwave.switchMultilevelV1.switchMultilevelStartLevelChange(upDown: upDown, ignoreStartLevel: 1, startLevel: 0))
List<String> stopLevelChange(){
    return [
            secure(zwave.switchMultilevelV1.switchMultilevelStopLevelChange())
            ,"delay 200"
            ,secure(zwave.basicV1.basicGet())
Can this be addressed in the next release? It's a super small change. If you open source the driver code for Generic Z-Wave Shades, I'll send you a pull request. Thank you!
Do you know that your shades work with this? Mine don't, but they're really blinds and not shades, where the usefulness is probably not as apparent.
If you want a starting place for something that vaguely resembles a generic shade driver, you can start with mine that I wrote for mine, which are iBlinds v3 units (I also have a driver for their v2, but I wouldn't recommend starting with that one since it has a couple workarounds for v2 device oddities). You can probably remove everything related to configuring Z-Wave parameters (lines 31-44, 60-62, and 93-100; possibly more), which are specific to the units I wrote this for. Otherwise, this would probably give you a good starting point.
I forked this, and this is my modification to add start/stopLevelChange.
Everything works, but there's still a bug for reporting the shade status in the dashboard which I have yet had the time to fix.
The built-in Generic Z-Wave Shades driver doesn't have that issue. All it's missing is the start/stopLevelChange methods. I'm just hoping the devs can add those 2 methods and the driver will be complete.
