Add a Tuya Hub to bulbs mesh?
Hi!
I own a HE C7 with a very stable zigbee mesh, in which I am adding new Gledopto Pro zigbee bulbs. As these bulbs works as repeaters, I was thinking of following the guidance of creating a new mesh using another hub. But I live in Brazil, where it is impossible to find another Hubitat and the Hue bridge has a prohibitive price. So, I would like to know if it would be possible to use a generic Tuya zigbee 3.0 hub to create a mesh network with these lamps and integrate it with the HE.
Indirectly. For example, the Tuya Hub and Hubitat both have Node-RED integrations. So you could integrate each of them with Node-RED, and use Node-RED to either create all your automations, or to pass information from a Tuya Hub-paired device to a virtual Hubitat device.
Thanks @aaiyar, great idea! I will try work this solution since I have a Rasp lost somewhere around here!
@marcusvrsilva did you try? it work?
@roberto.grosso.rgr, I integrated the bulbs through a Phillips Hue hub. It`s working perfectly!
Hi did you try also the NODE-Red whit the tuya?
Hi, @roberto.grosso.rgr! No, I didn't try.
