is there a way to access the device details - Data - deviceID
ive tried ${device.deviceId} but that not the id number i was looking for
Depends on what exactly you are looking for... But try ${device.deviceNetworkId}
I'm after the value '4' from the screen shot, its like the model number
Like the manufacturer Id number
Long version, I have a driver for two different trv, one reports temperature and the other doesn't. So using the model type, "deviceId" above, it handles it differently
What you are looking for is
getDataValue and even updateDataValue
https://docs.hubitat.com/index.php?title=Driver_Object#Additional_to_be_documented
I only recently started using that stuff.
ending up calling this from configure
zwave.manufacturerSpecificV2.manufacturerSpecificGet().format()
then storng it
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (cmd.manufacturerName) {
updateDataValue("manufacturer", cmd.manufacturerName)
if (cmd.productTypeId) {
updateDataValue("productTypeId", cmd.productTypeId.toString())
if (cmd.productId) {
updateDataValue("productId", cmd.productId.toString())
and using it
if (state.productId != "4") {
