So, I’ve discovered the Hubitat Elevatio C-8 Pro because I have talked to Google AI and watched a few youtube videos. Seems the logical choice for what I plan to do. That is, mainly, control 10 independent lights placed in shelving. 10 led strip lights that can be dimmed and are colour temperature adjustable.
The suggestion was to use a 32 Channel 96A RGBW DMX 512 LED Decoder Controller DMX Dimmer DC5-24V and an ArtNet DMX 1024 Ethernet Lighting Controller Interface CR021R.
This is where I’m totally lost. Is this what I need? Is this over the top? It seems the ArtNet is designed for something totally different to my use.
The plan is to have a few things on my smart network – security camera, Hive thermostats, an Amazon echo dot, wireless switch to turn off the shelving lights without having to use the app (SNZB-01M).
What do you suggest?
Where can I learn more to educate myself about this? (from the start!)
I suspect you are right to ask these questions. The few times I have heard Artnet and DMX Controllers mentioned they are very high-end robust setups. Though it may work with hubitat, I suspect it won't be a straight forward or easy deployment. The first big hurdle would be if there is even a integration for the controller device. The led strips themselves really aren't part of the equation. It is the controller that makes the difference
Hubitat generally works with devices that work on on of a few types of networks. Zwave, zigbee, or your Lan/wifi. There are a few different devices that are sold that support each of those network types. I can only think of one two zwave controllers which are from inovellie, and zooz. There is one primary maker of zigbee controllers called gledopto. There controllers can be found in a bunch of kits. Last There are 2 main wifi based controllers: wled,pixelblaze. You can also buy complete kits with a wifi controller from a few companies such as Govee.
So basically you pick the led type you want. You mention CT and dimming only. You also need to figure out pixel density and if it will be IC controlled. Find the strip you want to use. Then select a controller that can handle the strip with the density you want and a power supply to support it. Lastly figure out the install. If you pick up the parts separately it will be cheaper, but getting fulll kits from Govee, Hue, Lifx, or gledapto can make it easier.
I wonder what made the AI suggest the Artnet solution.
I think I first asked google what I needed to control the led strips. It suggested a GLEDOPTO Zigbee controller. Then I told it I have 10 independent lights which would each need its own controller. Asking it to find something that could do the job of 10 separate controllers it came up with the DMX512. This was much cheaper than buying individual controllers. However, if I can't easily add it to the Hubitat it's not an option.
I'm planning on using 24v Seamless with adjustable white led strips. IC control not required (if I understand that correctly! I'm not looking to control sections of the strip, just the whole thing x 10.)
Is there a single controller unit that can handle that many individual LED strips and works with Hubitat? Or are 10 controllers the way to go? One concern is trying to turn on/off or change the temperature colour of them all at once and getting "radio traffic jam". Is this a thing!?
It's the same with the power supply - to control the dimming - is that from the power supply? Do I need to have 10 of these? Is there a device that has multiple independent 24v outputs?
I don’t think my setup is anything extreme or out of the norm. I was hoping to find people that had similar setups.
Thanks.
I guess my question is why do you need 10 independent Led Strips. Why not have all strips connected to one controller and just wire them together in series. Even if you use one controller, that controller is going to have wires to it for each strip. The only real advantage would likely be power as you would use one power source vs the one for each. If you used IC strips you could in theory have one device and then effects that are only light up parts of it at a time. So each part could represent a section or space.
As already discussed a key is going to be using Individually Controlled (IC) LED strips, some additional wiring, and making sure you have enough power.
Something like this could work, I have had good luck with the single, dual, and 4 channel ones.
Obviously you need an EU version though.
WLED will give you want you want better than the Zigbee versions, but those are great too.
Thank you ACKmySYN, seems to be thousands of controllers - daunting for a newbie. Next is trying to understand the power supply, cable size etc and not have one strip brighter than the other.
I was looking at seamless CCT strips, so now trying to find an addressable version. Is there such a thing?
Next problem, the conduit I used might not be big enough! Any one fancy coming to help with digging this out the walls!?
Rereading your posts, I think it may be worth thinking/planning for multiple controllers actually.
That 8m distance is going to be a pain to work with/around.
Your reference picture shows a group of 3 shelves. Is this what you have but multiple around the house?
I would actually think/planning for multiple controllers based on distance/need, this may better suit your physical and potential home automation requirements:
controller per shelf group(s)
reduces power and data line runs
supports some availability if a controller dies
potentially easier/simplier automation
For shelf lighting you don’t need super dense strips (144 pixel or COB). It could be a waste of $ per strip, increased heat, and power draw.
A good 60-90 pixel strip with good defuser should get the job done.
Higher density is more for if you’ll see them straight on.
There are lots of YouTube videos out there comparing strips density for use case.
If you’re looking for CCT only
You could potentially go with these strips (I have a bunch and like them)
And a few of these controllers (Yes they are RGBCCT but you’ll run them in CCT mode)
I couldn’t find the CCT only controllers I have available on Amazon, they are all unavailable right now.
I’ve had luck with simple short runs with the RGB version of this, the CCT version should work but you’d probably want more controllers then.
