Abode driver won't log in
I have suddenly run into a problem that logging into the Abode driver from Hubitat fails as follows:
I use an RM rule that triggers periodically or also on events systemstart or Abode reports 'IsLoggedIn=false' and issues the custom action 'login() on Abode'
Is anyone experiencing this problem or does anyone have suggestions.
Hubitat C7 version 2.3.5.152
Abode Iota version 7.0V
I did a reboot on both Hubitat hub and Abode Iota.
Here are additional log entries:
Yes. My log shows the below action last night after the HE trigger for the mode to change:
Also, I have an auto login rule that has been working just fine for a few months, but stopped working reliably about 3-4 days ago. I was just in the process of writing a more frequent rule....
I REALLY wish someone with the coding skills could port the local Abode integration from HA to Hubitat....I'm fine paying for an Abode subscription, even though the integration is not local (would FAR prefer local), but if the online integration even with a PAID Abode subscription won't work, I will need to look elsewhere. So disappointing.
Mine started working again for apparent reason. That makes it one of those mysteries of technology that I may never get to the bottom of...
Likely something was up with the destination server and not hubitat.
