I have a Zebra shade and the zemismart motor. I want to be able to have 4 functions but after playing with the driver and reading through the forum I can't find what i'm looking for.
Via HE how do I set these levels?
I want to open the zebra shade to this level
lastly, how did you guys adjust your chain? my zebra shades came with this chain
I cut the chain because it was way too long, and now I notice it's getting stuck going through the Zemismart or getting stuck trying to go through the zebra shade once I adjusted the chain so the clip that's holding it beaded chain together isn't going through the zemismart motor.
My chain is similar. Make sure you're using the correct cog on the motor itself. As to amount it's opening, use percentages. Here is my rule that opens from close to 50% in the mornings...
Thanks, I was able to get the beaded chain to work better once I switched the cog.
Do you have this section set up? so it knows the difference between rolling/up down the blinds fully vs that short up/down movement to give the "shades" are open/closed look?
@ So you want position to be 50 Here is mine I open the kitchen shade fully but open the blinds to 55% (I'll note for my blinds I use iblinds v3 controllers but it still applies to the am43)
I tried all of that before posting for example, if I click the step close or step open, the "Current states" shows it's opening or closing but the blinds don't move, the only way to get it to move is to click "open/close or on/off"
