There are Pause buttons in all the Rule apps except Mode Lighting. Is this a purposeful omission of just an oversight?
It does not have pause simply because there is nothing particularly automatic about the app, it being manually fired.
However, you can disable an instance of it from the Apps page. The gray X in the upper right corner of the page reveals a column with boxes where you can selectively disable any app.
Hi Bruce. I know this option works but just selecting the app pause it or a hub reboot is needed?
I rebooted the hub when I used it.
No, reboot is not necessary to use this.
Thank you.
As a new user, one of the things I appreciate is consistency. While this may not be an "automation" it is something I may want to temporarily pause. Without the X selected, the app does not show up as Paused or disabled.
