on reboot getting lots of warnings regarding 3rd reality multi presence nightlight r3
seems to work after any ideas what this is?
ps not releated to beta.. has been coming up during reboots for a long time.. just decided to post it.
Maybe try my R3 driver and see if the same errors appear:
you mean not the built in driver
Correct, not the stock driver that you referenced in this thread’s title.
yep trying now.. but will report next time i reboot the hub that is the only time they come up.
i am happy to say using your driver now and that the device has updated to 1.00.40 air quality works when i blow into the device even after it has gone to zero..
the AQI number (not your issue though) is total bs.. saying 800 is good is a misnomer.. the issue is whatever they are reporting is not the standard AQI which is a documented and known entity.. sigh..
thanks again and will let you know about the unkown attrs when i reboot.
Yeah, their “AQI“ terminology is quite suspect, however, I did adopt it because that is what they used.
You might want to reach out to them and see if there is a bug about the AQI. Most major AQI system out there (China, EU, UK, US, Australia, India, etc...) max out at 500 (or less). They have been pretty responsive when I have asked questions, and it could be something as simple as "we changed it, but left out a decimal point... 800 is actually 8.00, we will fix that...".
rebooted your driver fixes the unknown attrs in the log during boot up
