3phase switch recomendations
Try pairing it again, currently, nothing is received from the device...
Do you have a C-8 or a C-7 hub?
If paired successfully (and if the device stays connected), you should see debug log messages coming automatically from this device, even when using the HE inbuilt 'Device' driver.
C8
Maybe there is need to reset the device itself. There is a switch pairing/work on it.
I deleted the device and switched to pairing and it was found now it cant connect to hub.
Yeah Ill re pair it but later on another tasks at hand.
Do you have a second device using this driver? I see another “Tuya Zigbee Metering Plug” in your previous post…
Maybe you are looking at wrong device / wrong logs?
Ok, just update the driver again when you start making new tests later today.
Yes its updated
device successfully reconected and online:) manual on off is shown in the driver...
logs i believe that the power metering is not working correct the compressor turn on but no consumption was indicated
logs after on
Logs
  • 1
  • Live
dev:562023-05-13 10:47:15.911infoKompresor malarnia breaker id = 1650812160
dev:562023-05-13 10:47:15.906debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 018C13030010455455312D494F542D5A696762656500, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[01, 8C, 13, 03, 00, 10, 45, 54, 55, 31, 2D, 49, 4F, 54, 2D, 5A, 69, 67, 62, 65, 65, 00]]
dev:562023-05-13 10:47:15.899debugKompresor malarnia parse: description is catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 018C13030010455455312D494F542D5A696762656500
dev:562023-05-13 10:47:15.866infoKompresor malarnia (18) AlarmSet2 : 67174575
dev:562023-05-13 10:47:15.862debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 018B1200000C0101006403010113040100AF, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[01, 8B, 12, 00, 00, 0C, 01, 01, 00, 64, 03, 01, 01, 13, 04, 01, 00, AF]]
dev:562023-05-13 10:47:15.852debugKompresor malarnia parse: description is catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 018B1200000C0101006403010113040100AF
dev:562023-05-13 10:47:15.815infoKompresor malarnia RTX (06) Phase A : [01, 8A, 06, 00, 00, 08, 09, 2E, 00, 00, 00, 00, 00, 00] value=2057
dev:562023-05-13 10:47:15.810debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 018A06000008092E000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[01, 8A, 06, 00, 00, 08, 09, 2E, 00, 00, 00, 00, 00, 00]]
Successfully pairing the device again is a piece of very good news! A simple ZIgbee pairing became a problem lately ... : (
I see the voltage reading ( 235.0 V), but to get more from this device I will need more logs...
Does it have a load? Is the load only on Phase A or on the 3 phases ? What is the approximately load value in Watts ( V/A ) ?
The decoding of the voltage, current and power is now available in the Tuya Zigbee Metering Plug (w/ healthStatus) ver. 1.7.6 2023-05-13
Your device is sending the voltage readings only, the current and the power are zeroes, don't know why... Let me know if you see any power readings later.
Thanks I'll check it today
Yeah, it's not sending any wats or amps...Updated driver... Its 8 Kw compressor it turns on in a cycle, but no readings received while active.
Logs
dev:562023-05-15 12:50:28.826traceKompresor malarnia sendZigbeeCommands : [he raw 0xDDC4 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200, he raw 0xDDC4 1 0x01 0x0702 {10 00 00 00 00}, delay 200, he rattr 0xDDC4 0x01 6 0 {}, delay 2000]
dev:562023-05-15 12:50:28.771debugKompresor malarnia polling all 0x0B04 attributes
dev:562023-05-15 12:50:28.770debugKompresor malarnia polling.. refreshAll is true
dev:562023-05-15 12:50:28.767infoKompresor malarnia refresh()...
dev:562023-05-15 12:50:28.633infoKompresor malarnia RTX(19) breaker id = ETU1-IOT-Zigbee)
dev:562023-05-15 12:50:28.624debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAB213030010455455312D494F542D5A696762656500, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[EA, B2, 13, 03, 00, 10, 45, 54, 55, 31, 2D, 49, 4F, 54, 2D, 5A, 69, 67, 62, 65, 65, 00]]
dev:562023-05-15 12:50:28.619debugKompresor malarnia parse: description is catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAB213030010455455312D494F542D5A696762656500
dev:562023-05-15 12:50:28.606infoKompresor malarnia Under Voltage Threshold is 175 enabled:ON
dev:562023-05-15 12:50:28.603infoKompresor malarnia Over Voltage Threshold is 275 enabled:ON
dev:562023-05-15 12:50:28.601infoKompresor malarnia Over Current Threshold is 100 enabled:ON
dev:562023-05-15 12:50:28.599debugKompresor malarnia RTX(18) AlarmSet2 : [EA, B1, 12, 00, 00, 0C, 01, 01, 00, 64, 03, 01, 01, 13, 04, 01, 00, AF]
dev:562023-05-15 12:50:28.596debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAB11200000C0101006403010113040100AF, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[EA, B1, 12, 00, 00, 0C, 01, 01, 00, 64, 03, 01, 01, 13, 04, 01, 00, AF]]
dev:562023-05-15 12:50:28.592debugKompresor malarnia parse: description is catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAB11200000C0101006403010113040100AF
dev:562023-05-15 12:50:28.573debugKompresor malarnia ignored power 0 W (change from 0.0 is less than 1 W)
dev:562023-05-15 12:50:28.571infoKompresor malarnia DinRail(06) Active. Power : 0 W (raw 0)
dev:562023-05-15 12:50:28.569debugKompresor malarnia ignored amperage 0 A (change from 0.0 is less than 25 mA)
dev:562023-05-15 12:50:28.567infoKompresor malarnia RTX (06) Phase A Current : 0 V (raw 0)
dev:562023-05-15 12:50:28.505infoKompresor malarnia voltage is 227 V
dev:562023-05-15 12:50:28.503infoKompresor malarnia RTX (06) Phase A Voltage : 227 V (raw 2270)
dev:562023-05-15 12:50:28.501debugKompresor malarnia RTX (06) Phase A combined reporting data: [EA, B0, 06, 00, 00, 08, 08, DE, 00, 00, 00, 00, 00, 00]
dev:562023-05-15 12:50:28.498debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAB00600000808DE000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[EA, B0, 06, 00, 00, 08, 08, DE, 00, 00, 00, 00, 00, 00]]
dev:562023-05-15 12:50:28.494debugKompresor malarnia parse: description is catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAB00600000808DE000000000000
dev:562023-05-15 12:50:28.447infoKompresor malarnia RTX(09) Fault : 0
dev:562023-05-15 12:50:28.443debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAAF0905000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[EA, AF, 09, 05, 00, 01, 00]]
dev:562023-05-15 12:50:28.438debugKompresor malarnia parse: description is catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAAF0905000100
dev:562023-05-15 12:50:28.396debugKompresor malarnia Kompresor malarnia energy is 0.0 kWh (no change)
dev:562023-05-15 12:50:28.394debugKompresor malarnia energy_total=0.08, state.lastResetEnergy=0.08
dev:562023-05-15 12:50:28.392infoKompresor malarnia (01) Forward/Real Energy : 8 raw
dev:562023-05-15 12:50:28.388debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAAE0102000400000008, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[EA, AE, 01, 02, 00, 04, 00, 00, 00, 08]]
dev:562023-05-15 12:50:28.383debugKompresor malarnia parse: description is catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAAE0102000400000008
dev:562023-05-15 12:50:28.340debugKompresor malarnia (16) switch : 1
dev:562023-05-15 12:50:28.336debugKompresor malarnia parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAAD1001000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DDC4, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[EA, AD, 10, 01, 00, 01, 01]]
dev:562023-05-15 12:50:28.331debugKompresor malarnia parse: description is catchall: 0104 EF00 01 01 0040 00 DDC4 01 00 0000 02 01 EAAD1001000101
