3-Way Switch Control
I have two GE Z-Wave wall switches in my kitchen that need to control an Aeotec relay module operating under counter lights. The idea is to have the switches mimic each other so if one has turned on the lights the other can turn it off and vise-versa. Like a wired 3-way switch, but without the wiring.
I have tried this in the simple lighting app, but it seems Hubitat doesn't like the two switches controlling each other. Should this be a rule of some sort?
Hello Itdavis,
GE makes a switch module just for this purpose. Look for the Home Automation 120 VAC 3-Way Auxiliary Add-On Switch, Almond/White Paddles.
https://www.homedepot.com/p/GE-Home-Automation-120-VAC-3-Way-Auxiliary-Add-On-Switch-Almond-White-Paddles-12723/205798442
Try this switch binding apps.
That did it!
Thanks for the solution.
