Best choices for Energy monitors and why? Obviously would like to be able to integrate to Hubitat.
I have a 3 phase supply so will need to be compatible with that.
I'm guessing there aren't ones which can work out how much each thing is using without doing it plug by plug although some of the big things (Ground Source Pump) are direct wired of course.
Aeotec (Aeon Labs) is what I use and I believe that is what @Cobra had unknowingly ordered. I can vouch for mine as a laundry monitor and I played with it as an energy monitor for a bit, just for grins. It was pretty accurate compared with the Smart Meter readings from my house. It's a v1 so old, but good. Don't believe Andy had an opportunity to try his, because he does not have 3-phase power coming into his flat.
I don’t have 3 phase into my house no.
I use a single phase Aeon for ‘whole House’ monitoring
I have an unusual one with a driver that sends me a pushover msg every month with usage.
Unfortunately my driver will probably only work with the exact version I bought (which I cannot find any more)
