Not a biggie. Just curious as to why the 3 dot menu does not appear when using a Relay Template. Clicking in the location where the 3 dot menu should appears reveals the tile info dialog window. If I change the template in use, the 3 dot menu appears in the tile. Changing tile size and location does not make a difference.
