They can be set, or double tap to bypass the setting for full brightness
Yes, and the Nortek stick from the C4 also works on the Pi, so you can try HA before you spend any money
That allows the switch to limit the max and min brightness. It does not cause the switch to turn on at the previously used brightness level which is what I was referring to.
That is true... It's almost doable. Though you could also potentially write a rule which would help do that. But it's a pain.. I've done it for a couple of switches.
I don't actually have a c4 so either way it looks like I have to buy something.
