As per the title, is there any way to hide certain dashboards. I would prefer certain dashboards to only be opened through the main dashboard where it has a tile linked to the dashboard. Removes the clutter when opening up the android app where you select the dashboard.
Also, can the word "Dashboards" be removed from the dash board tiles? It doesn't need to be there in my case, and it also messes up tiles that aren't very high on mobile devices where I have it auto size to fit the screen.
From what I have seen I can't see a way to "hide" the dashboards, only restrict access. There is an option to restrict access through the Hubitat Dashboard App, but the dashboard still appears in the list of dashboards, but an error is displayed instead of the dashboard. Shame. Maybe someone else has a way to do this.
The tile labels at the bottom of the tile can be removed, but it is quite a tedious process, unfortunately. You need to adjust the CSS for the tile. There is a post on CSS more generally, I'll try to find it soon, if you still get stuck I can try to provide an example as well.
That appears to do a much more thorough job of explaining it The first link to another post was the one I think I was referring to when I played around with doing this.
This has now got me looking at changing certain tiles font sizes and justifications.. So has added far more value than just hiding the "Dashboards" text.
Have you considered a direct link to the Dashboard instead of going through the Hubitat app? In the child app for your dashboard (Apps > Hubitat Dashboard), you should have LAN and cloud links for that dashboard. Choose whichever works for you, then try navigating directly to that page in the browser app of your choice (you can even create a link to it on the home/main screen of your phone/tablet so it will look like an app). You'll get a lot less UI around the Dashboard that way, and you'll have a harder time getting to others that aren't explicitly linked with a tile (but PIN protection would really be best if you're concerned about others since you can still do it with a tap on the logo).
I have now made a direct link to the main dashboard. The main tablet controller now uses Kiosk Dashboard that starts at the main dashboard url. So fast and appears like a dedicated controller now. Very happy.
I know I am tapping in a bit late, but I wanted to add one thing that might help. If you look CLOSELY in the lower right hand corner of the phone shot below you can just hardly see the green check mark + gear which is normally up top. The code below removes the HE logo/Dashboard name, and relocates the top right stuff to bottom and sets the opacity .2.
If you set these dashes to only have access to given devices you can effectively 'lock down' a device to only the dashboards you provide links to. You can also set the opacity to .0 and you will not see the "settings stuff". It will still be clickable, but out sight, out mind and all. Enjoy.
.dashboard div .header{position:fixed;bottom:-1em;right:1em;z-index:999;opacity:.2;zoom:.6;-moz-transform:scale(.6)}
.wrapper{height:100%;margin-top:0;padding-top:1em}
.dashBack,.dashName{display:none}
.dashboard div .header>.flex-auto.justify-end,.dashboard div .header>.flex-auto.justify-end>.flex{display:inline-block}
Thank you so much! That's exactly what I needed to make my Dashboards look much nicer. I have organized all my devices with linked dashboards and can quickly and conveniently access them by type, location, etc.
