[2.5.2.127] C8 - Sonos Integrator
@gopher.ny
Not sure if it is intended, but I cannot change the name of imported Sonos devices. They follow the name given in the Sonos app. If the name is changed in the app, it changes in Hubitat also. Can this be addressed?
There's a setting in the Sonos Device's preferences called Disable name synchronization that should do the trick:
Wow! Didn't see it... Thank you!
I have disabled name synchronization but still find that the Volume up/down adjustment value is routinely reset to a value other than what I manually specified.
Is there a way to disable this behavior?
I need more specifics on when you observe this, particularly what state things were in before
After some additional digging, I cannot confidently attribute the behavior I witnessed to the Sonos Integrator.
The Volume up/down % preference was verifiably reset to its default value on all of my Sonos devices, but it has not happened since that one/initial time. I'm increasingly suspect that the value may not have been configured correctly (via the Preference Manager app) and was thus simply reverting to it's previously configured value.
Based on this, I don't think there's anything to investigate with regards to the Integrator. I'll post again should something change this...
