2.4.3.155 Alert there are SmartStart devices pending inclusion
Just upgraded my C-8 Pro to 2.4.3.155. Now there is an alert that there are SmartStart devices pending inclusion. Currently running ZWave JS without any problems.
The release notes for 2.4.3.155 say "Added a section to show SmartStart devices pending inclusion on the Devices page (for hubs running ZWaveJS only)", but when I go to the Devices page there is no such section. I have previously added a few devices using SmartStart and @jtp10181 's SmartStart Manager app without any problems. As far as I know there are not any devices pending inclusion.
Any idea how I can get rid of this alert? Tagging @gopher.ny
Open up my app and see if anything in there is showing as pending. You could always uncheck them which removes them out of the hubs SS list and keeps the data in the app only. That should get rid of the alert on the hub anyway.
That solved it. On your app I had 3 devices that were checked in the list and did show up on the mobile app SmartStart list. They were all previously included. None were pending. When I unchecked the 3 devices in your app, they were removed from the mobile app SmartStart list and the alert went away. Thanks for the quick response.
But did that fix the issue or just work around it?
Getting the same here. Duplicate entry from a failed paring of an LR contact sensor.
Work around.
Duplicate where?
Was a duplicate of a contact sensor that was already paired (looked like a failed pairing of that LR Sensor) I deleted the entry and the error went away
I didn't ask what, I asked where. So it sounds like it was in SS? Its not possible to have duplicates as far as I know. Unless maybe you disabled it in my app then scanned it a second time from the mobile app. So one was disabled (saved only in the app) and one was enabled on the hub.
I only just installed your app, and I only have one LR Contact sensor (Zooz) at the moment. When I clicked on it, it showed not installed. I just assumed it was a ghost of somesort for that device (my poor use of the term duplicate. Ghost is more reasonable even though my z-wave table is clean)
I'm getting that same alert. All of the items in the SmartStart (seen by the app) are showing "included".
I haven't been able to check the list on the app because I wasn't home & even using my VPN to remotely connect didn't seem to convince the Android app to "locally connect". Apparently, it refuses to show SmartStart things if it thinks it has a cloud connection.
@gopher.ny the alert appears, but gives no clue as to what devices are an issue.
Fix coming in the next build.
Edit: 2..4.3.156 is out with the fix.
