2.4.0.146 Hue Bridge Integration (A05C3D – Hue Bridge) Errors
About once a day, I am getting errors like this example screenshot
This is basically an occasional error you'll get when using the V2 API, as you are, and the JSON data with event changes from Hue is quite long and truncated (presumably by the hub, cause TBD, for some reason). States should catch up on the next poll -- and that's one reason the default and recommended setting is to keep that enabled, even if at a lower frequency. The missing "instant" events are the only harm. For now, the above is the best safeguard if this happens occasionally in your environment.
The settings are all at the "recommended". Thanks! I just hate seeing that red in my logs :slight_smile:
