I obviously wrote something stupid while coding up a custom app and now none of the app instances will load; getting this error: java.lang.NoClassDefFoundError: Could not initialize class
I think the problem is I was calling a common method from within a @Field static final Map declaration...
I managed to remove the app instances by going directly to their status page and hitting remove (note: really missing the old gear icon in the app list for this particular case!).
Is there an equivalent shortcut or endpoint I could use to delete the code from the hub @gopher.ny ? When I try to access the code page, I get a blank screen, so no remove button, no errors in logs
App status is still there, it's just the "i" on the far right now.
Did you try a hub reboot before trying to delete the offending code again? That's helped me when I've gotten myself stuck a few times, though never with the particular problem you're noting, which might very well come back when the app code gets re-initialized on hub reboot...
