I’m running a C8 Pro, I’ve had several Hubitat models now, the update process is super fast and simple. For some reason the .181 update will not play nice with me. Usually it takes about 3 seconds to download a new update, this one is taking about 20-30 seconds per single percentage point, and then fails after 20 minutes at around the 50% mark. Anyone else experiencing this?
Check yourhubip>>settings>>network settings
If your network speed says auto, changed it to fixed 100, if fixed 100 change to auto. Then try again
Hmmm…through remote access (I’m stuck at work) it just times out, it wont let me get passed clicking on my ip.
try rebooting remotely then check it
No luck, I’ll be home in a few hours, I’ll update you once I can access that.
There we go, that was it! It was set at 100 for some reason, I never changed it, but everything is updating as we speak at its usual speed now, thank you!
If you ever run into this kind of issue again, the same toggle of the network speed will usually resolve it. So you might have a point in the future where you have to change from Auto back to 100 to jiggle things loose... It's a bit of a quirk.
I wonder why my c7 says no update available. As it is, it says varsion 2.3.9.176. 2.3.9.181 is only 5 versions out?
Check solution above, check your network speed.
I had a moment recently when one of my hubs lost cloud connection and gave me a "No update available" message. Rebooted hub and update appeared.
2.3.9.184 is the current release... ![]()
This also happened to me a few times with latest versions that had network tweeks, reboot and then update!
I wonder why my c7 says no update available. I tried changing the network speeds with reboots, no ipdate available. It is stuck on 176. I did a complete reset on the hub before this, because it would not update and it did not help at all.
Same as your other issue, your hub cannot reach the internet. Some sort of networking issue on your end.
Hubitat package manager wont install
I already have suggestions in the other thread so please continue over there
2 posts were merged into an existing topic: Hubitat package manager wont install
