I was running 2.3.9.142 on my two hubs (one is a C8, the other is a C8 Pro) and decided to try upgrading both to 2.3.9.174 tonight.
After the upgrade, all the meshed devices on both sides were OFFLINE. The Hub Mesh page on both hubs shows no hubs available. I've rebooted both hubs, rebooted the router, rebooted the hubs again, etc. I clicked the "refresh" button next to "Active hubs" several times, clicked "reconnect" and that had no effect.
I ended up going back to 2.3.9.142 on both--and, still, no mesh.
However, after maybe 10 minutes or so, it came back to life on 2.3.9.142.
There seems to be a dose of black magic on how the hub mesh finds it's buddies--has something changed with the way the hub mesh works?
Note that I'm using static IPs. Both hubs are plugged into a small network switch right off my ASUS router--there's nothing complex about my network. I was able to ping from each of the hubs to the other one using the Network tools.
I guess I'm going to wait a bit before i try upgrading again...
Thanks!
