2.3.9.141 Dashboard 1.0 "blank for auto fit" no longer working
Topic title says it - Dashboards that used to perfectly fill the screen (PC or mobile) are now too narrow and either too short or too tall.
These are existing dashboards, right?
I don't have any existing 1.0 dashboards (all my 1.0 dashboards are customized w/3rd-party integrations) but I did create a new dashboard and it looks OK, FWIW.
If you create a new dashboard does it also have the same problem?
Yes, same problem with a new 1.0 Dashboard.
Strange, not sure what I'm not seeing it either with existing or new dashboards. (I found an existing unmodified dashboard to check.)
The new version (142) fixed the problem on one of my hubs, but not completely on the other.
The "fixed" hub had been reverted to 136 (which fixed it), then bumped to 142. I've tried that with the other "broken" hub, but while PC Dashboard displays are correct, the Dashboard displays on the mobile (Android) app are still problematic.
Noted, will fix shortly.
143 fixed it. Thanks!
