2.3.8.140 seems stuck in an update loop?
Under the category might help, won't hurt...
  • Clear cache in your browser (depending on what you're using interweb will have instructions)
  • Re-do the download of the platform version via the endpoint /hub/advanced/downloadPlatform/234
  • Cross fingers
Yeah man, appreciate that but I’ve tried all those already. The platform download endpoint spun for a while and then timed out. It can’t be browser cache as I’ve tried 3 or 4 across multiple computers. Crossing fingers was the first act :joy:
I wonder if the soft reset with logs purge indicated here would help clear things out better to get it updated? @bobbyD thoughts on why he cannot update?
I read the post again and there are instructions in there for if you are unable to update!
Hmmmm - I will give this a shot this evening. I’m not sure if I’m seeing the symptoms of the z-wave lockup (I have had the hub hard lock a few times recently, so maybe)
Thanks for the pointer though, another thing to test! I was also kinda wondering at this point if waiting til .141 (or just .next) would fix this for me too. Either way the help is very appreciated :slightly_smiling_face:
This sounds more like a network problem. Do you use any special firewalls, firewall rules? Mind sharing more about your network?
It's worth a shot to eliminate that possibility. Please go to the following end point: yourHubIP*/hub/zwaveDebugDisable then reboot the hub
*yourHubIP - use your actual IP address as assigned by your router
This did it! I used the instructions in the link above to revert to 2.3.7, hit the zWaveDebugDisable endpoint, did a reboot with a rebuild and log purge, then it took 2.3.8.140 no problem!
@bobbyD do I need to do anything to re-enable zWaveDebug after this process or is it fine as it is?
Thanks so much to everyone who pitched in here. Appreciate that nobody just went straight to "RTFM" as I just hadn't seen this link that ended up being so helpful :slight_smile:
Glad it worked. And no, you do not need to do anything to re-enable the logging. It was turned on in our effort to get to the bottom of some edge case Z-Wave issues.
Just to add I had the same problem (extracting update -> download failed) and this worked for me too:
I was not able to update for a long time and was stuck on 2.3.8.123. I ran the above, rebooted (with DB rebuild/log purge) and it updated fine after that. Thanks.
