2.3.5.152 upgrade and virtually everything is broken
We are still troubleshooting the first group of devices - the mains-powered routers.
Please add all of these to the app, and test whether they are responding to on/off commands.
You must have the routers first working rock-solid, before we go to the non-Aqara devices and last to Aqara devices (including P1).
Here I can propose you to use this driver temporily for testing the Zigbee plugs connectivity. When you are sure that all plugs have stable Zigbee connectivity to the C_8 hub, you can revert back to using the stock drivers.
You can use the Ping button to measure the round-trip-time - this is the time in miliseconds between sending a simple ping command and receiving the response.
Ping button
Normally, the RTT should not vary by more than a few hundred milliseconds. If you look at the live logs, you should see results like this :
RTT
You can set up a simple RM5 rule to test the connectivity of all your plugs once every minute or even every 15 seconds, like this:
RM5 ping rule
You can leave the pings running for hours - a healthy Zigbee network should not be affected in any way by this activity.
Update: the driver was updated to count the number of successful and the number of failed pings ( version 2.1.3 2023/08/09 10:47 PM)
Failed Pings count
