I think there might be something else going on. From what I can tell, I didn't change anything about how the mode is being reported. Because the events are showing up in the rule, I think this may be a bug with either Rule Machine or the rule itself.
Are you running 2.3.2.139? Changed for Custom Attribute triggers was fixed in 2.3.2.138 -- known to be broken before that. I cannot reproduce any failure with this.
There is a state variable called prevState. Show me what that looks like:
Yes, I went from .135 to .139 before the tests tonight.
Now, this time, it seems to be working.
I wonder if there was some latent issue--because I edited the triggers to create 3 more triggers a bit ago, after the previous failed test (so my rule would work), and I just now deleted those triggers for this test. Thus changing the event subscriptions a bit between my earlier failed test and this one. I suppose it's possible that helped address the issue.
If so, I need to figure out which other 5.1 rules I need to work on (and what to do) to make sure they fire properly going forward.
That app has never been triggered with changed, given the prevState value. Since it's never been triggered, %value% does not show anything.
Please remove or disable the app, create a new one; turn on Event and Trigger logging, and be sure it has been Installed. Cause it to be triggered. Then show the state value for prevState, as well as logs for it.
Note that CurrentState is the name of a local variable, which I set to "na" upon creation of the rule.
After doing that, I disabled the new rule and enabled the old rule, then created individual conditions (in addition to using changed). Again, that worked:
I'm not sure what "prevState" is supposed to show, as it is showing only the Private Boolean and the local variable; not the mode information or "value" from the trigger).
To take all the Ring stuff out, I created a VERY simple device driver that let me toggle the "mode" value between off & home. Driver code at the bottom.
Mine is broken again this morning and not responding to the event trigger...so need to run some similar tests. I may need to try to convert to condition driven rather than event driven.
Using my latest example (and supplied demonstration driver), has anybody else been able to reproduce this issue where a custom attribute "changes" and the event is detected--but the rule fails to trigger?
I just updated to 2.3.2.140. I saved the device driver code from above, created a virtual device using that driver, created an RM5.1 rule triggering off the custom attribute "mode" changing, and had a single "log" line in it to see if the rule executed or not. I'm not getting the rule to execute although the triggering event does show up in the log. For me, it's 100% reproducible-every time. I'm wondering if there's something the driver is doing wrong (the "sendEvent" command?) or what might be going on.
