Yeah, there is an incompatibility between 129 and later builds with respect to setting a variable to a device attribute.
Best plan is to sit tight until we get the hot fix out, which will be today.
As usual, HE staff goes above and beyond on dealing with issues that arise. Companies I've worked at/with in the past would not even be aware/looking at this until mid-day on Monday at best, maybe a fix by the end of the week. Just another reason why HE is the best, IMHO.
Hot fix that fixes this problem coming shortly. 2.3.1.134.
Wow...and .134 is already out!
Is there anything special we have to do after we install this platform update? Any particular database version backup we should install?
And thank you, Bruce, and the Hubitat staff for going above and beyond the call of duty.
It should just fix the problem. Nothing special to do. Let me know...
You obviously haven't been to AZ...
LOL...I have, lovely state, but tons of sun. I did forget to mention the incredible amount of ice cubes required to maintain a livable temperature inside the dome.
Installed 134 with my rolled back 129 system. Tested the two previously broken rules, all is OK here. Thank you.
Thanks a bunch for getting that out so quickly.
