tried resetting, rebooting....zwave repair etc,
no joy =(
no joy =(
Can you screen shot these nodes on the z-wave details page?
Ok.. So what is it not doing.. Logs show activity, z-wave details shows nothing wrong.
The only thing of note is the slow 9.6 speed and a repeated packet, so probably some packet loss
Won't turn on, off, dim, brighten........nothing.
It's always been solid. Use them all the time - they're my main frontroom lights.
What driver are you using?.. And can you turn on debug logging and trigger it?
* Fibaro Dimmer 2 (FGD-212) Driver - For use on Hubitat
* Author: Robin Winbourne
* Date: 2018-04-01
metadata {
definition (name: "Fibaro Dimmer 2 - RB", namespace: "Hubitat", author: "Robin Winbourne") {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Power Meter"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Switch Level"
attribute "scene", "number" //Extending Fibaro Dimmer 2 devices with scene attribute
attribute "syncPending", "bool" // Updates when parameters have synced
command "reset"
command "changeSingleParam"
// Fingerprints:
fingerprint mfr: "010F", prod: "0102", model: "1000"
fingerprint type: "1101", mfr: "010F", cc: "5E,86,72,59,73,22,31,32,71,56,98,7A"
fingerprint type: "1101", mfr: "010F", cc: "5E,86,72,59,73,22,31,32,71,56,98,7A", sec: "20,5A,85,26,8E,60,70,75,27", secOut: "2B"
preferences {
input name: "param1", type: "number", range: "1..98", defaultValue: "1", required: true,
title: "1. Minimum brightness level. " +
"Set automatically during the calibration process, but can be changed afterwards. " +
"Values: 1-98 = Brightness level (%). Default value: 1."
input name: "param2", type: "number", range: "2..99", defaultValue: "99", required: true,
title: "2. maximum brightness level. " +
"Values: 2-99 = Brightness level (%). Default value: 99."
input name: "param3", type: "number", range: "1..99", defaultValue: "1", required: true,
title: "3. Incandescence Level of CFLs. " +
"The Dimmer 2 will set to this value after first switch on. It is required for warming up and switching dimmable compact fluorescent lamps and certain types of light sources. " +
"Values: 1-99 = Brightness level (%). Default value: 1"
input name: "param4", type: "number", range: "0..255", defaultValue: "0", required: true,
title: "4. Incandescence Time of CFLs. " +
"The time required for switching compact fluorescent lamps and certain types of light sources. " +
"Values: 0 = Function Disabled. 1-255 = 0.1-25.5s in 0.1s steps. Default value: 0."
input name: "param5", type: "number", range: "1..99", defaultValue: "1", required: true,
title: "5. Dimming Step Size (Auto). " +
"The percentage value of a dimming step during automatic control. " +
"Values: 1-99 = Dimming step (%). Default value: 1."
input name: "param6", type: "number", range: "0..255", defaultValue: "1", required: true,
title: "6. Dimming Step Time (Auto). " +
"The time of a single dimming step during automatic control. " +
"Values: 0-255 = 0-2.55s, in 10ms steps. Default value: 1."
input name: "param7", type: "number", range: "1..99", defaultValue: "1", required: true,
title: "7. Dimming Step Size (Manual). " +
"The percentage value of a dimming step during manual control. " +
input name: "param8", type: "number", range: "0..255", defaultValue: "5", required: true,
title: "8. Dimming Step Time (Manual). " +
"The time of a single dimming step during manual control. " +
"Values: 0-255 = 0-2.55s, in 10ms steps. Default value: 5."
input name: "param9", type: "enum", defaultValue: "1", required: true,
options: [["0" : "0 - Off"],
["1" : "1 - Restore Previous State"]],
title: "9. Dimmer dtate After Power Failure. " +
"The Dimmer can save its current state before a power failure and restore that state after a power failure. Default value: 1"
input name: "param10", type: "number", range: "0..32767", defaultValue: "0", required: true,
title: "10. Timer functionality (auto off). " +
"Automatically switch off the device after a specified time. " +
"Values: 0 = Function Disabled. 1-32767 = time in seconds. Default value: 0."
input name: "param11", type: "enum", defaultValue: "255", required: true,
options: [["0" : "0 - All ON not active, All OFF not active"],
["1" : "1 - All ON not active, All OFF active"],
["2" : "2 - All ON active, All OFF not active"],
["255" : "255 - All ON active, All OFF active"]],
title: "11. ALL ON / ALL OFF function. " +
"Dimmer response to SWITCH_ALL_SET commands which can be sent from other zwave devices. Default value: 255."
input name: "param13", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - Readout"],
["1" : "1 - force auto-calibration of the load WITHOUT Fibaro Bypass 2"],
["2" : "2 - force auto-calibration of the load WITH Fibaro Bypass 2"]],
title: "13. Force auto-calibration. " +
"Set this parameter to 1 or 2 to trigger an auto calibration. Parameter switches back to 0 upon completion (but not updated here). Default value: 0."
input name: "param15", type: "number", range: "0..99", defaultValue: "30", required: true,
title: "15. Burnt out bulb detection. " +
"Power variation, compared to standard power consumption (measured during calibration). " +
"Values: 0 = Function Disabled. 1-99 = Power variation (%). Default value: 30."
input name: "param16", type: "number", range: "0..255", defaultValue: "5", required: true,
title: "16. Time Delay for Burnt Out Bulb/Overload Detection. " +
"Time delay (in seconds) for LOAD ERROR or OVERLOAD detection. " +
"Values: 0 = Detection Disabled. 1-255 = Time delay (s). Default value: 5."
input name: "param19", type: "number", range: "0..99", defaultValue: "0", required: true,
title: "19. Forced switch on brightness level. " +
"Switching on the dimmer will always set this brightness level. " +
"Values: 0 = Function Disabled. 1-99 = Brightness level (%). Default value: 0."
input name: "param20", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - Momentary switch"],
["1" : "1 - Toggle switch"],
["2" : "2 - Roller blind switch"]],
title: "20. Switch Type Selection. " +
"Physical switch type: Momentary, Toggle, or Roller Blind (middle rest position, up to brighten, down to dim). Default value: 0."
input name: "param21", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - 0xFF"],
["1" : "1 - Current Level"]],
title: "21. Value Sent to Associated Devices on Single Click. " +
"0xFF will set associated devices to their last-saved state. Current Level will synchronise the state of all devices with this dimmer. Default value: 0."
input name: "param22", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - Change on Every Switch State Change"],
["1" : "1 - Synchronise with Switch State"]],
title: "22. Assign Toggle Switch Status to Device Status. " +
"By default, each change of toggle switch position results in an on/off action regardless the physical connection of contacts. Default value: 0."
input name: "param23", type: "enum", defaultValue: "1", required: true,
options: [["0" : "0 - Double-click DISABLED"],
["1" : "1 - Double-click ENABLED"]],
title: "23. Double-click sets Max Brightness. " +
"Double-clicking will set brightness level to maximum. Default value: 1."
input name: "param24", type: "number", range: "0..31", defaultValue: "0", required: true,
title: "24. Command Frames Sent to 2nd and 3rd Association Groups (S1 Associations). " +
"Determines which actions will not result in sending frames to association groups. Values (add together): " +
"0 = All actions sent to association groups, " +
"1 = Do not send when switching ON (single click), " +
"2 = Do not send when switching OFF (single click), " +
"4 = Do not send when changing dimming level (holding and releasing), " +
"8 = Do not send on double click, " +
"16 = Send 0xFF value on double click. Default value: 0."
input name: "param25", type: "number", range: "0..31", defaultValue: "0", required: true,
title: "25. Command Frames Sent to 4th and 5th Association Groups (S2 Associations). " +
input name: "param26", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - 3-way switch function for S2 DISABLED"],
["1" : "1 - 3-way switch function for S2 ENABLED"]],
title: "26. 3-way Switch Function. " +
"Switch S2 also controls the dimmer when in 3-way switch mode. Function is disabled if parameter #20 is set to 2 (roller blind switch). Default value: 0."
input name: "param27", type: "number", range: "0..15", defaultValue: "15", required: true,
title: "27. Association Group Security Mode. " +
"Defines if commands sent to association groups are secure or non-secure. Values (add together): " +
"0 = all groups sent as non-secure, " +
"1 = 2nd group sent as secure, " +
"2 = 3rd group sent as secure, " +
"4 = 4th group sent as secure, " +
"8 = 5th group sent as secure. " +
"E.g. 15 = all groups (2-5) sent as secure. Default value: 15."
input name: "param28", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - Function DISABLED"],
["1" : "1 - Function ENABLED"]],
title: "28. Scene Activation. " +
"Defines if SCENE_ACTIVATION_SET commands are sent. " +
"For Momentary: S1 input: 16 = 1 x click, 14 = 2 x click, 12 = hold, 13 = release. " +
"S2 input: 26 = 1 x click, 24 = 2 x click, 25 = 3 x click, 22 = hold, 23 = release (see manual for other switch types). Default value: 0."
input name: "param29", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - Standard Mode"],
["1" : "1 - S1 operates as S2, S2 operates as S1"]],
title: "29. Swap S1 and S2. " +
"Swap the roles of S1 and S2 without changes to physical wiring. Default value: 0."
input name: "param30", type: "enum", defaultValue: "2", required: true,
options: [["0" : "0 - Force leading edge mode"],
["1" : "1 - Force trailing edge mode"],
["2" : "2 - Automatic (based on auto-calibration)"]],
title: "30. Load Control Mode. " +
"Override the dimmer mode (i.e. leading or trailing edge). Default value: 2."
input name: "param32", type: "enum", defaultValue: "2", required: true,
options: [["0" : "0 - On/Off mode DISABLED (dimming is possible)"],
["1" : "1 - On/Off mode ENABLED (dimming not possible)"],
title: "32. On/Off Mode. " +
"This mode is necessary when connecting non-dimmable light sources. Default value: 2."
input name: "param34", type: "enum", defaultValue: "1", required: true,
options: [["0" : "0 - No soft-start"],
["1" : "1 - Short soft-start (0.1s)"],
["2" : "2 - Long soft-start (0.5s)"]],
title: "34. Soft-Start. " +
"Time required to warm up the filament of halogen bulbs. Default value: 1."
input name: "param35", type: "enum", defaultValue: "1", required: true,
options: [["0" : "0 - No auto-calibration"],
["1" : "1 - Auto-calibration after first power on only"],
["2" : "2 - Auto-calibration after each power on"],
["3" : "3 - Auto-calibration after first power on and after each LOAD ERROR"],
["4" : "4 - Auto-calibration after each power on and after each LOAD ERROR"]],
title: "35. Auto-calibration. " +
"Determines when auto-calibration is triggered. Default value: 1."
input name: "param37", type: "enum", defaultValue: "1", required: true,
options: [["0" : "0 - Device disabled until command or external switch"],
["1" : "1 - Three attempts to turn on the load"]],
title: "37. Behaviour After OVERCURRENT or SURGE. " +
"The dimmer will turn off when a surge or overcurrent is detected. Default value: 1."
input name: "param39", type: "number", range: "0..350", defaultValue: "250", required: true,
title: "39. Power limit - OVERLOAD. " +
"Reaching the defined value will result in turning off the load. Additional apparent power limit of 350VA is active by default. " +
"Values: 0 = Function Disabled, 1-350 = Power limit (W). Default value: 250."
input name: "param40", type: "enum", defaultValue: "3", required: true,
options: [["0" : "0 - No reaction"],
["1" : "1 - Turn ON the load"],
["2" : "2 - Turn OFF the load"],
["3" : "3 - Load blinking"]],
title: "40. Response to General Purpose Alarm. " +
"Default value: 3."
input name: "param41", type: "enum", defaultValue: "2", required: true,
title: "41. Response to Water Flooding Alarm. " +
"Default value: 2."
input name: "param42", type: "enum", defaultValue: "3", required: true,
title: "42. Response to Smoke, CO or CO2 Alarm. " +
"Default value: 3."
input name: "param43", type: "enum", defaultValue: "1", required: true,
title: "43. Response to Temperature Alarm. " +
"Default value: 1."
input name: "param44", type: "number", range: "1..32767", defaultValue: "600", required: true,
title: "44. Time of alarm state. " +
"Values: 1-32767 = Time (s). Default value: 600."
input name: "param45", type: "enum", defaultValue: "1", required: true,
["1" : "1 - Send an alarm frame"]],
title: "45. OVERLOAD Alarm Report. " +
"Power consumption above Power Limit. Default value: 1."
input name: "param46", type: "enum", defaultValue: "1", required: true,
title: "46. LOAD ERROR Alarm Report. " +
"No load, load failure, or burnt out bulb. Default value: 1."
input name: "param47", type: "enum", defaultValue: "1", required: true,
title: "47. OVERCURRENT Alarm Report. " +
"Short circuit, or burnt out bulb causing overcurrent. Default value: 1."
input name: "param48", type: "enum", defaultValue: "1", required: true,
title: "48. SURGE Alarm Report. " +
"Dimmer 2 output overvoltage. Default value: 1."
input name: "param49", type: "enum", defaultValue: "1", required: true,
title: "49. OVERHEAT and VOLTAGE DROP Alarm Report. " +
"Critical temperature, or low voltage. Default value: 1."
input name: "param50", type: "number", range: "0..100", defaultValue: "10", required: true,
title: "50. Power Reports Threshold. " +
"Power level change that will result in a new power report being sent. " +
"Values: 0 = Reports disabled, 1-100 = % change from previous report. Default value: 10."
input name: "param52", type: "number", range: "0..32767", defaultValue: "3600", required: true,
title: "52. Reporting Period. " +
"The time period between consecutive power and energy reports. " +
"Values: 0 = Reports disabled, 1-32767 = Time period (s). Default value: 3600."
input name: "param53", type: "number", range: "0..255", defaultValue: "10", required: true,
title: "53. Energy Reports Threshold. " +
"Energy level change that will result in a new energy report being sent. " +
"Values: 0 = Reports disabled, 1-255 = 0.01-2.55 kWh. Default value: 10."
input name: "param54", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - Self-measurement DISABLED"],
["1" : "1 - Self-measurement ENABLED"]],
title: "54. Self-measurement. " +
"Include power and energy consumed by the device itself in reports. Default value: 0."
input name: "param58", type: "enum", defaultValue: "0", required: true,
options: [["0" : "0 - Standard algorithm"],
["1" : "1 - Based on calibration data"],
["2" : "2 - Based on control angle"]],
title: "58. Method of Calculating Active Power. " +
"Useful in 2-wire configurations with non-resistive loads. Default value: 0."
input name: "param59", type: "number", range: "0..500", defaultValue: "0", required: true,
title: "59. Approximated Power at Max Brightness. " +
"Determines the approximate value of the power that will be reported by the device at it's maximum brightness level. " +
"Values: 0-500 = Power (W). Default value: 0."
input name: "paramAssociationGroup1", type: "bool", defaultValue: true, required: true,
title: "The Dimmer 2 provides the association of five groups. " +
"1st Association Group 'Lifeline'. Default value: true"
input name: "paramAssociationGroup2", type: "bool", defaultValue: true, required: true,
title: "2nd Association Group 'On/Off (S1)'. Default value: true"
input name: "paramAssociationGroup3", type: "bool", defaultValue: false, required: true,
title: "3rd Association Group 'Dimmer (S1)'. Default value: false"
input name: "paramAssociationGroup4", type: "bool", defaultValue: false, required: true,
title: "4th Association Group 'On/Off (S2)'. Default value: false"
input name: "paramAssociationGroup5", type: "bool", defaultValue: false, required: true,
title: "5th Association Group 'Dimmer (S2)'. Default value: false"
log.trace(description)
log.debug("RAW command: $description")
def result = null
if (description != "updated") {
def cmd = zwave.parse(description.replace("98C1", "9881"), [0x20: 1, 0x26: 3, 0x32: 3, 0x25: 1, 0x98: 1, 0x70: 1, 0x85: 2, 0x9B: 1, 0x90: 1, 0x73: 1, 0x30: 1, 0x28: 1, 0x72: 1])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed '${description}' to ${result.inspect()}"
return result
def zwaveEvent(hubitat.zwave.commands.sceneactivationv1.SceneActivationSet cmd) {
log.debug( "Scene ID: $cmd.sceneId")
log.debug( "Dimming Duration: $cmd.dimmingDuration")
sendEvent(name: "scene", value: "$cmd.sceneId", data: [switchType: "$settings.param20"], descriptionText: "Scene id $cmd.sceneId was activated", isStateChange: true)
log.debug( "Scene id $cmd.sceneId was activated" )
// Devices that support the Security command class can send messages in an encrypted form;
// they arrive wrapped in a SecurityMessageEncapsulation command and must be unencapsulated
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
log.trace(cmd)
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x26: 3, 0x32: 3, 0x25: 1, 0x98: 1, 0x70: 1, 0x85: 2, 0x9B: 1, 0x90: 1, 0x73: 1, 0x30: 1, 0x28: 1, 0x72: 1]) // can specify command class versions here like in zwave.parse
if (encapsulatedCommand) {
return zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
log.trace(cmd)
dimmerEvents(cmd)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
log.trace(cmd)
dimmerEvents(cmd)
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv3.SwitchMultilevelReport cmd) {
log.trace(cmd)
dimmerEvents(cmd)
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
log.trace(cmd)
dimmerEvents(cmd)
def dimmerEvents(hubitat.zwave.Command cmd) {
log.trace(cmd)
def result = []
def value = (cmd.value ? "on" : "off")
def switchEvent = createEvent(name: "switch", value: value, descriptionText: "$device.displayName was turned $value")
result << switchEvent
if (cmd.value) {
result << createEvent(name: "level", value: cmd.value, unit: "%")
if (switchEvent.isStateChange) {
result << response(["delay 3000", zwave.meterV2.meterGet(scale: 2).format()])
return result
def zwaveEvent(hubitat.zwave.commands.meterv3.MeterReport cmd) {
log.trace(cmd)
if (cmd.meterType == 1) {
if (cmd.scale == 0) {
return createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kWh")
} else if (cmd.scale == 1) {
return createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kVAh")
} else if (cmd.scale == 2) {
return createEvent(name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W")
} else {
return createEvent(name: "electric", value: cmd.scaledMeterValue, unit: ["pulses", "V", "A", "R/Z", ""][cmd.scale - 3])
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
//Handles Configuration Reports and sets syncPending to False
log.trace("zwaveEvent(): Configuration Report received: ${cmd}")
sendEvent(name: "syncPending", value: false, isStateChange: true)
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv4.SensorMultilevelReport cmd) {
log.trace("zwaveEvent(): SensorMultilevelReport received: ${cmd}")
def zwaveEvent(hubitat.zwave.Command cmd) {
log.trace(cmd)
log.debug "No handler for $cmd"
// Handles all Z-Wave commands we aren't interested in
createEvent(descriptionText: cmd.toString(), isStateChange: false)
def on() {
log.trace("on")
secureSequence([
zwave.basicV1.basicSet(value: 0xFF),
zwave.switchMultilevelV1.switchMultilevelGet()
def off() {
log.trace("off")
secureSequence([
zwave.basicV1.basicSet(value: 0x00),
def poll() {
log.trace("poll")
secureSequence([
zwave.meterV2.meterGet(scale: 0),
def refresh() {
log.trace("trace")
secureSequence([
def reset() {
log.trace("reset")
return secureSequence([
zwave.switchMultilevelV1.switchMultilevelGet(),
zwave.meterV2.meterReset(),
def setLevel(level) {
log.trace("setlevel")
if(level > 99) level = 99
secureSequence([
zwave.basicV1.basicSet(value: level),
], 5000)
def changeSingleParam(paramNum, paramSize, paramValue) {
log.debug "changeSingleParam(paramNum: $paramNum, paramSize: $paramSize, paramValue: $paramValue)"
def cmds = secureSequence([
zwave.configurationV1.configurationSet(parameterNumber: paramNum, size: paramSize, scaledConfigurationValue: paramValue)
cmds
def updated() {
log.debug "configureAfterSecure()"
sendEvent(name: "syncPending", value: true, isStateChange: true)
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, scaledConfigurationValue: param1.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, scaledConfigurationValue: param2.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: param3.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 4, size: 2, scaledConfigurationValue: param4.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 5, size: 1, scaledConfigurationValue: param5.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 6, size: 2, scaledConfigurationValue: param6.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 7, size: 1, scaledConfigurationValue: param7.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 8, size: 2, scaledConfigurationValue: param8.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 9, size: 1, scaledConfigurationValue: param9.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 10, size: 2, scaledConfigurationValue: param10.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 11, size: 2, scaledConfigurationValue: param11.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 13, size: 1, scaledConfigurationValue: param13.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 15, size: 1, scaledConfigurationValue: param15.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 16, size: 2, scaledConfigurationValue: param16.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 19, size: 1, scaledConfigurationValue: param19.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 20, size: 1, scaledConfigurationValue: param20.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 21, size: 1, scaledConfigurationValue: param21.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 22, size: 1, scaledConfigurationValue: param22.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 23, size: 1, scaledConfigurationValue: param23.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 24, size: 1, scaledConfigurationValue: param24.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 25, size: 1, scaledConfigurationValue: param25.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 26, size: 1, scaledConfigurationValue: param26.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 27, size: 1, scaledConfigurationValue: param27.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 28, size: 1, scaledConfigurationValue: param28.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 29, size: 1, scaledConfigurationValue: param29.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 30, size: 1, scaledConfigurationValue: param30.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 32, size: 1, scaledConfigurationValue: param32.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 34, size: 1, scaledConfigurationValue: param34.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 35, size: 1, scaledConfigurationValue: param35.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 37, size: 1, scaledConfigurationValue: param37.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 39, size: 2, scaledConfigurationValue: param39.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 40, size: 1, scaledConfigurationValue: param40.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 41, size: 1, scaledConfigurationValue: param41.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 42, size: 1, scaledConfigurationValue: param42.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 43, size: 1, scaledConfigurationValue: param43.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 44, size: 2, scaledConfigurationValue: param44.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 45, size: 1, scaledConfigurationValue: param45.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 46, size: 1, scaledConfigurationValue: param46.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 47, size: 1, scaledConfigurationValue: param47.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 48, size: 1, scaledConfigurationValue: param48.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 49, size: 1, scaledConfigurationValue: param49.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 50, size: 1, scaledConfigurationValue: param50.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 52, size: 2, scaledConfigurationValue: param52.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 53, size: 2, scaledConfigurationValue: param53.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 54, size: 1, scaledConfigurationValue: param54.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 58, size: 1, scaledConfigurationValue: param58.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 59, size: 2, scaledConfigurationValue: param59.toInteger())
// Register for Group 1
if(paramAssociationGroup1) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:1, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:1, nodeId: [zwaveHubNodeId]))
// Register for Group 2
if(paramAssociationGroup2) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:2, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:2, nodeId: [zwaveHubNodeId]))
// Register for Group 3
if(paramAssociationGroup3) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:3, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:3, nodeId: [zwaveHubNodeId]))
// Register for Group 4
if(paramAssociationGroup4) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:4, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:4, nodeId: [zwaveHubNodeId]))
// Register for Group 5
if(paramAssociationGroups5) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:5, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:5, nodeId: [zwaveHubNodeId]))
cmds
private secure(hubitat.zwave.Command cmd) {
log.trace(cmd)
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private secureSequence(commands, delay=200) {
log.debug "$commands"
delayBetween(commands.collect{ secure(it) }, delay)
Not sure how to do that....?
-=edit=-
Something about the updare broke the RB driver. I've just swapped to this:
Fibaro Dimmer 2
chat_bubble_outline
help_outline
Rooms
Devices
Dashboards
Apps
Settings
Subscriptions
Developer
Apps Code
Drivers Code
Libraries Code
Bundles
Logs
Fibaro Dimmer 2Ā« Drivers code Import
Spaces
4
No wrap
HelpDeleteSave
1
2
3
* Fibaro Dimmer 2 (US)
4
5
* github: Eric Maycock (erocm123)
6
* email: erocmail@gmail.com
7
* Date: 2016-07-31 8:03PM
8
* Copyright Eric Maycock
9
10
11
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
12
* in compliance with the License. You may obtain a copy of the License at:
13
14
* http://www.apache.org/licenses/LICENSE-2.0
15
16
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
17
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
18
* for the specific language governing permissions and limitations under the License.
19
20
* added button to the current state so Hubitat apps can pick up the 3 buttons and added doubletap and releasable button: borristhecat 24/5/19
21
* added basicSet zwave event so physical button presses are handled by the hub. /eriktack 20190812
22
* added physical and digital send events. Split logging for info and debug. Added the ability to hide the configure settings. borristhecat 26/8/19
23
24
25
metadata {
26
definition (name: "Fibaro Dimmer 2", namespace: "erocm123", author: "Eric Maycock", importUrl: "https://raw.githubusercontent.com/erocm123/Hubitat/master/Drivers/fibaro-dimmer-2.src/fibaro-dimmer-2.groovy") {
27
28
capability "Switch"
29
30
31
capability "Configuration"
32
capability "Sensor"
33
// capability "Polling"
34
35
36
capability "PushableButton"
37
capability "HoldableButton"
38
capability "ReleasableButton"
39
capability "DoubleTapableButton"
40
capability "Health Check"
41
42
attribute "needUpdate", "string"
43
attribute "firmware", "String"
44
ā
45
fingerprint mfr: "010F", prod: "0102", model: "2000", deviceJoinName: "Fibaro Dimmer 2"
46
ā
47
fingerprint deviceId: "0x1101", inClusters: "0x72,0x86,0x70,0x85,0x8E,0x26,0x7A,0x27,0x73,0xEF,0x26,0x2B"
48
fingerprint deviceId: "0x1101", inClusters: "0x5E,0x20,0x86,0x72,0x26,0x5A,0x59,0x85,0x73,0x98,0x7A,0x56,0x70,0x31,0x32,0x8E,0x60,0x75,0x71,0x27"
49
50
51
52
preferences {
53
input name: "settingEnable", type: "bool", title: "Enable setting", defaultValue: false
54
input name: "enableDebugging", type: "bool", title: "Enable Debug Logging?", defaultValue: false
55
input name: "enableInfo", type: "bool", title: "Enable Info Logging?", defaultValue: true
56
if (settingEnable) input description: "Once you change values on this page, the corner of the \"configuration\" icon will change orange until all configuration parameters are updated.", title: "Settings", displayDuringSetup: false, type: "paragraph", element: "paragraph"
57
if (settingEnable) generate_preferences(configuration_model())
Terms of Service
Documentation
Community
Support
Copyright 2021 Hubitat, Inc.
...and it instantly works. But I've lost all use of scenes etc, there's very little config options on this driver.
I'd used the same driver, no changes, absolutely fine from day one. I can't see how it's anything but the update which has caused it to stop working. Anything else I can do to assist?
I have no problems using this driver. Just need to add the UK fingerprint. i.e.:
"fingerprint mfr: "010F", prod: "0102", model: "1000", deviceJoinName: "Fibaro Dimmer 2""
that driver doesn't have scenes enabled, which i think is the problem the OP has
no idea. mine doesn't.
if i swap to another, it works. odd.
Mine works without problem.
After abit of testing I found that two of my dimmers lost the s2 switching which was set up for scenes. It was activated in the driver but when i looked into the detail's I noticed that parameter 28 was set to 0 when it should be 1 tried a few times setting it to one reinstall the drive and still didn't change. I used zwave tools driver to set it 1 which worked.
Might be worth having a look at your parameter settings
My Fibaro Smart Implant running my garage door had the same issue, but a zwave repair did solve my issue.
Ps Iām using a community driver.
Odd. Haven't done anything. Left my original driver in place (wasn't working).
Returned home from work - everything works fine again. Wtf...
sorry to drag this up again, but I've lost use of scenes again.
any ideas? It's one of only 2 zwave devices.
This is the current driver:
metadata {
capability "Switch"
capability "Sensor"
preferences {
private getCommandClassVersions() {
0x20: 1, // Basic
0x25: 1, // Switch Binary
0x70: 1, // Configuration
0x98: 1, // Security
0x60: 3, // Multi Channel
0x8E: 2, // Multi Channel Association
0x26: 1, // Switch Multilevel
0x87: 1, // Indicator
0x72: 2, // Manufacturer Specific
0x5B: 1, // Central Scene
0x32: 3, // Meter
0x85: 2, // Association
0x86: 1, // Version
0x75: 2 // Protection
def parse(description) {
def result = null
if (description.startsWith("Err 106")) {
state.sec = 0
result = createEvent(descriptionText: description, isStateChange: true)
} else if (description != "updated") {
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
//log.debug("'$cmd' parsed to $result")
} else {
log.debug "Couldn't zwave.parse '$description'"
result
logging(cmd)
def request = update_needed_settings()
if(request != []){
return [response(commands(request))]
} else {
return null
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd, ep=null) {
logging("$cmd : Endpoint: $ep")
/*def event
if (!ep) {
event = [createEvent([name: "switch", value: cmd.value? "on":"off"])]
return event*/
logging(cmd)
logging("sceneId: $cmd.sceneId")
logging("dimmingDuration: $cmd.dimmingDuration")
logging("Configuration for preference \"Switch Type\" is set to ${settings."20"}")
if (settings."20" == "2") {
Info("Switch configured as Roller blinds")
switch (cmd.sceneId) {
// Roller blinds S1
case 10: // Turn On (1x click)
buttonEvent(1, "pushed")
break
case 13: // Release
buttonEvent(1, "released")
break
case 14: // 2x click
buttonEvent(1, "doubleTapped")
break
case 17: // Brightening
buttonEvent(1, "held")
break
// Roller blinds S2
case 11: // Turn Off
buttonEvent(2, "pushed")
break
case 13: // Release
buttonEvent(2, "released")
break
buttonEvent(2, "doubleTapped")
break
case 15: // 3x click
buttonEvent(3, "pushed")
break
case 18: // Dimming
buttonEvent(2, "held")
break
default:
logging("Unhandled SceneActivationSet: ${cmd}")
break
} else if (settings."20" == "1") {
Info("Switch configured as Toggle")
// Toggle S1
case 10: // Off to On
break
case 11: // On to Off
break
break
// Toggle S2
case 20: // Off to On
break
case 21: // On to Off
break
case 24: // 2x click
break
case 25: // 3x click
break
default:
break
} else {
if (settings."20" == "0") Info("Switch configured as Momentary") else logging("Switch type not configured")
// Momentary S1
case 16: // 1x click
break
break
case 12: // held
break
case 13: // release
break
// Momentary S2
case 26: // 1x click
break
break
break
case 22: // held
break
case 23: // release
break
default:
break
def buttonEvent(button, value) {
Info("buttonEvent() Button:$button, Value:$value")
sendEvent(name: value, value: button, isStateChange:true, type: "physical")
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
logging(cmd)
dimmerEvents(cmd, (!state.lastRan || now() <= state.lastRan + 2000)?"digital":"physical")
def dimmerEvents(hubitat.zwave.Command cmd, source = null) {
def result = []
def switchEvent = createEvent(name: "switch", value: value, descriptionText: "$device.displayName was turned $value [${source?source:'physical'}]", type: source?source:"physical")
if (cmd.value) {
result << createEvent(name: "level", value: cmd.value, unit: "%", descriptionText: "$device.displayName was set to ${cmd.value}% [${source?source:'physical'}]", type: source?source:"physical")
return result
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
logging(cmd)
state."association${cmd.groupingIdentifier}" = cmd.nodeId[0]
def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
state.sec = 1
def result = zwaveEvent(encapsulatedCommand)
result = result.collect {
if (it instanceof hubitat.device.HubAction && !it.toString().startsWith("9881")) {
response(cmd.CMD + "00" + it.toString())
} else {
it
result
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def encapsulatedCommand = zwave.getCommand(cmd.commandClass, cmd.command, cmd.data,1)
} else {
log.warn "Unable to extract CRC16 command from ${cmd}"
logging("Unhandled Z-Wave Event: $cmd")
logging(cmd)
sendEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kWh", type: "digital")
sendEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kVAh", type: "digital")
sendEvent(name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W", type: "digital")
} else {
sendEvent(name: "electric", value: cmd.scaledMeterValue, unit: ["pulses", "V", "A", "R/Z", ""][cmd.scale - 3], type: "digital")
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd){
logging(cmd)
def map = [:]
switch (cmd.sensorType) {
case 4:
map.name = "power"
map.value = cmd.scaledSensorValue.toInteger().toString()
map.unit = cmd.scale == 1 ? "Btu/h" : "W"
break
default:
map.descriptionText = cmd.toString()
createEvent(map)
def on() {
state.lastRan = now()
commands([zwave.basicV1.basicSet(value: 0xFF), zwave.basicV1.basicGet()])
def off() {
commands([zwave.basicV1.basicSet(value: 0x00), zwave.basicV1.basicGet()])
def refresh() {
logging("$device.displayName refresh()")
def cmds = []
if (state.lastRefresh != null && now() - state.lastRefresh < 5000) {
logging("Refresh Double Press")
def configuration = new XmlSlurper().parseText(configuration_model())
configuration.Value.each
if ( "${it.@setting_type}" == "zwave" ) {
cmds << zwave.configurationV1.configurationGet(parameterNumber: "${it.@index}".toInteger())
cmds << zwave.firmwareUpdateMdV2.firmwareMdGet()
} else {
cmds << zwave.meterV2.meterGet(scale: 0)
cmds << zwave.meterV2.meterGet(scale: 2)
cmds << zwave.basicV1.basicGet()
state.lastRefresh = now()
commands(cmds)
def ping() {
logging("$device.displayName ping()")
def cmds = []
commands(cmds)
def setLevel(level, duration) {
logging("setLevel value:$level, duration:$duration")
def dimmingDuration = duration < 128 ? duration : 128 + Math.round(duration / 60)
logging("dimmingDuration: $dimmingDuration")
commands([
zwave.switchMultilevelV2.switchMultilevelSet(value: level < 100 ? level : 99, dimmingDuration: dimmingDuration),
logging("setLevel value:$level")
if(level < 1) level = 1
def cmds = []
cmds << zwave.basicV1.basicSet(value: level)
cmds << zwave.switchMultilevelV1.switchMultilevelGet()
commands(cmds)
def updated()
sendEvent(name: "numberOfButtons", value: 3)
state.enableDebugging = settings.enableDebugging
state.enableInfo = settings.enableInfo
logging("updated() is being called")
sendEvent(name: "checkInterval", value: 2 * 30 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
state.needfwUpdate = ""
def cmds = update_needed_settings()
sendEvent(name:"needUpdate", value: device.currentValue("needUpdate"), displayed:false, isStateChange: true)
commands(cmds)
def installed(){
log.warn "installed..."
private command(hubitat.zwave.Command cmd) {
if (getDataValue("zwaveSecurePairingComplete") == "true") {
} else {
cmd.format()
private commands(commands, delay=1500) {
delayBetween(commands.collect{ command(it) }, delay)
def generate_preferences(configuration_model)
def configuration = new XmlSlurper().parseText(configuration_model)
switch(it.@type)
case ["byte","short","four"]:
input "${it.@index}", "number",
title:"${it.@label}\n" + "${it.Help}",
range: "${it.@min}..${it.@max}",
defaultValue: "${it.@value}",
displayDuringSetup: "${it.@displayDuringSetup}"
break
case "list":
def items = []
it.Item.each { items << ["${it.@value}":"${it.@label}"] }
input "${it.@index}", "enum",
displayDuringSetup: "${it.@displayDuringSetup}",
options: items
break
case "decimal":
input "${it.@index}", "decimal",
break
case "boolean":
input "${it.@index}", "bool",
break
def update_current_properties(cmd)
def currentProperties = state.currentProperties ?: [:]
currentProperties."${cmd.parameterNumber}" = cmd.configurationValue
if (settings."${cmd.parameterNumber}" != null)
if (settings."${cmd.parameterNumber}".toInteger() == convertParam("${cmd.parameterNumber}".toInteger(), cmd2Integer(cmd.configurationValue)))
sendEvent(name:"needUpdate", value:"NO", displayed:false, isStateChange: true)
else
sendEvent(name:"needUpdate", value:"YES", displayed:false, isStateChange: true)
state.currentProperties = currentProperties
def update_needed_settings()
def cmds = []
def isUpdateNeeded = "NO"
if(!state.needfwUpdate || state.needfwUpdate == ""){
logging("Requesting device firmware version")
cmds << zwave.versionV1.versionGet()
if(!state.association1 || state.association1 == "" || state.association1 == "1"){
logging("Setting association group 1")
cmds << zwave.associationV2.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId)
cmds << zwave.associationV2.associationGet(groupingIdentifier:1)
if(!state.association2 || state.association2 == "" || state.association1 == "2"){
logging("Setting association group 2")
cmds << zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:zwaveHubNodeId)
cmds << zwave.associationV2.associationGet(groupingIdentifier:2)
if ("${it.@setting_type}" == "zwave"){
if (currentProperties."${it.@index}" == null)
if (device.currentValue("firmware") == null || it.@fw == "" || "${it.@fw}".indexOf(device.currentValue("firmware")) >= 0){
isUpdateNeeded = "YES"
logging("Current value of parameter ${it.@index} is unknown")
cmds << zwave.configurationV1.configurationGet(parameterNumber: it.@index.toInteger())
else if (settings."${it.@index}" != null && convertParam(it.@index.toInteger(), cmd2Integer(currentProperties."${it.@index}")) != settings."${it.@index}".toInteger())
logging("Parameter ${it.@index} will be updated to " + settings."${it.@index}")
def convertedConfigurationValue = convertParam(it.@index.toInteger(), settings."${it.@index}".toInteger())
cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(convertedConfigurationValue, it.@byteSize.toInteger()), parameterNumber: it.@index.toInteger(), size: it.@byteSize.toInteger())
sendEvent(name:"needUpdate", value: isUpdateNeeded, displayed:false, isStateChange: true)
return cmds
* Convert 1 and 2 bytes values to integer
def cmd2Integer(array) {
switch(array.size()) {
case 1:
array[0]
break
case 2:
((array[0] & 0xFF) << 8) | (array[1] & 0xFF)
break
case 3:
((array[0] & 0xFF) << 16) | ((array[1] & 0xFF) << 8) | (array[2] & 0xFF)
break
case 4:
((array[0] & 0xFF) << 24) | ((array[1] & 0xFF) << 16) | ((array[2] & 0xFF) << 8) | (array[3] & 0xFF)
break
def integer2Cmd(value, size) {
switch(size) {
case 1:
[value]
break
case 2:
def short value1 = value & 0xFF
def short value2 = (value >> 8) & 0xFF
[value2, value1]
break
case 3:
def short value3 = (value >> 16) & 0xFF
[value3, value2, value1]
break
case 4:
def short value4 = (value >> 24) & 0xFF
[value4, value3, value2, value1]
break
logging("${device.displayName} parameter '${cmd.parameterNumber}' with a byte size of '${cmd.size}' is set to '${cmd2Integer(cmd.configurationValue)}'")
return null
def zwaveEvent(hubitat.zwave.commands.firmwareupdatemdv2.FirmwareMdReport cmd){
logging("Firmware Report ${cmd.toString()}")
def firmwareVersion
switch(cmd.checksum){
case "3281":
firmwareVersion = "3.08"
break;
default:
firmwareVersion = cmd.checksum
state.needfwUpdate = "false"
updateDataValue("firmware", firmwareVersion.toString())
createEvent(name: "currentFirmware", value: firmwareVersion)
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
logging("${device.label?device.label:device.name}: ${cmd}")
if(cmd.applicationVersion != null && cmd.applicationSubVersion != null) {
def firmware = "${cmd.applicationVersion}.${cmd.applicationSubVersion.toString().padLeft(2,'0')}"
logging("${device.label?device.label:device.name}: Firmware report received: ${firmware}")
createEvent(name: "firmware", value: "${firmware}")
} else if(cmd.firmware0Version != null && cmd.firmware0SubVersion != null) {
def firmware = "${cmd.firmware0Version}.${cmd.firmware0SubVersion.toString().padLeft(2,'0')}"
def configure() {
logging("Configuring Device For Hubitat Use")
def cmds = []
if (cmds != []) commands(cmds)
def convertParam(number, value) {
switch (number){
case 201:
if (value < 0)
256 + value
else if (value > 100)
value - 256
else
value
break
case 202:
if (value < 0)
256 + value
value - 256
else
value
break
case 203:
if (value < 0)
65536 + value
else if (value > 1000)
value - 65536
else
value
break
case 204:
if (value < 0)
256 + value
value - 256
else
value
break
default:
value
break
private def logging(message) {
if (state.enableDebugging == null || state.enableDebugging == true) log.debug "$message"
private def Info(message) {
if (state.enableInfo == null || state.enableInfo == true) log.info "$message"
def configuration_model()
<configuration>
<Value type="byte" byteSize="1" index="1" label="Minimum brightness level" min="1" max="98" value="1" setting_type="zwave" fw="">
<Help>
(parameter is set automatically during the calibration process)
The parameter can be changed manually after the calibration.
Range: 1~98
Default: 1
</Help>
</Value>
<Value type="byte" byteSize="1" index="2" label="Maximum brightness level" min="2" max="99" value="99" setting_type="zwave" fw="">
<Help>
Range: 2~99
Default: 99
</Help>
</Value>
<Value type="byte" byteSize="1" index="5" label="Automatic control - dimming step size" min="1" max="99" value="1" setting_type="zwave" fw="">
<Help>
This parameter defines the percentage value of dimming step during the automatic control.
Range: 1~99
Default: 1
</Help>
</Value>
<Value type="short" byteSize="2" index="6" label="Automatic control - time of a dimming step" min="0" max="255" value="1" setting_type="zwave" fw="">
<Help>
This parameter defines the time of single dimming step set in parameter 5 during the automatic control.
Range: 0~255
Default: 1
</Help>
</Value>
<Value type="byte" byteSize="1" index="7" label="Manual control - dimming step size" min="1" max="99" value="1" setting_type="zwave" fw="">
<Help>
This parameter defines the percentage value of dimming step during the manual control.
Range: 1~99
Default: 1
</Help>
</Value>
<Value type="short" byteSize="2" index="8" label="Manual control - time of a dimming step" min="0" max="255" value="5" setting_type="zwave" fw="">
<Help>
This parameter defines the time of single dimming step set in parameter 7 during the manual control.
Range: 0~255
Default: 5
</Help>
</Value>
<Value type="list" byteSize="1" index="9" label="State of the device after a power failure" min="0" max="1" value="1" setting_type="zwave" fw="">
<Help>
The Dimmer 2 will return to the last state before power failure.
0 - the Dimmer 2 does not save the state before a power failure, it returns to the "off" position
1 - the Dimmer 2 restores its state before power failure
Range: 0~1
Default: 1
</Help>
<Item label="Off" value="0" />
<Item label="Previous State" value="1" />
</Value>
<Value type="short" byteSize="2" index="10" label="Timer functionality (auto - off)" min="0" max="32767" value="0" setting_type="zwave" fw="">
<Help>
This parameter allows to automatically switch off the device after specified time (seconds) from switching on the light source.
Range: 1~32767
Default: 0
</Help>
</Value>
<Value type="byte" byteSize="1" index="19" label="Forced switch on brightness level" min="0" max="99" value="0" setting_type="zwave" fw="">
<Help>
If the parameter is active, switching on the Dimmer 2 (S1 single click) will always set this brightness level.
Range: 0~99
Default: 0
</Help>
</Value>
<Value type="list" byteSize="1" index="20" label="Switch type" min="0" max="2" value="0" setting_type="zwave" fw="">
<Help>
Choose between momentary, toggle and roller blind switch.
Range: 0~2
Default: 0
</Help>
<Item label="Momentary" value="0" />
<Item label="Toggle" value="1" />
<Item label="Roller Blind" value="2" />
</Value>
<Value type="list" byteSize="1" index="22" label="Assign toggle switch status to the device status " min="0" max="1" value="0" setting_type="zwave" fw="">
<Help>
By default each change of toggle switch position results in action of Dimmer 2 (switch on/off) regardless the physical connection of contacts.
0 - device changes status on switch status change
1 - device status is synchronized with switch status
Range: 0~1
Default: 0
</Help>
<Item label="Default" value="0" />
<Item label="Synchronized" value="1" />
</Value>
<Value type="list" byteSize="1" index="23" label="Double click option" min="0" max="1" value="1" setting_type="zwave" fw="">
<Help>
set the brightness level to MAX
Range: 0~1
Default: 1
</Help>
<Item label="Disabled" value="0" />
<Item label="Enabled" value="1" />
</Value>
<Value type="list" byteSize="1" index="26" label="The function of 3-way switch" min="0" max="1" value="0" setting_type="zwave" fw="">
<Help>
Switch no. 2 controls the Dimmer 2 additionally (in 3-way switch mode). Function disabled for parameter 20 set to 2 (roller blind switch).
Range: 0~1
Default: 0
</Help>
</Value>
<Value type="list" byteSize="1" index="28" label="Scene activation functionality" min="0" max="1" value="1" setting_type="zwave" fw="">
<Help>
SCENE ID depends on the switch type configurations.
Range: 0~1
Default: 0
</Help>
</Value>
<Value type="list" byteSize="1" index="29" label="Switch functionality of S1 and S2" min="0" max="1" value="0" setting_type="disabled" fw="">
<Help>
This parameter allows for switching the role of keys connected to S1 and S2 without changes in connection.
Range: 0~1
Default: 0
</Help>
<Item label="Standard" value="0" />
<Item label="Switched" value="1" />
</Value>
<Value type="list" byteSize="1" index="35" label="Auto-calibration after power on" min="0" max="4" value="1" setting_type="zwave" fw="">
<Help>
This parameter determines the trigger of auto-calibration procedure, e.g. power on, load error, etc.
0 - No auto-calibration of the load after power on
1 - Auto-calibration performed after first power on
2 - Auto-calibration performed after each power on
3 - Auto-calibration performed after first power on or after each LOAD ERROR alarm (no load, load failure, burnt out bulb), if parameter 37 is set to 1 also after alarms: SURGE (Dimmer 2 output overvoltage) and OVERCURRENT (Dimmer 2 output overcurrent)
4 - Auto-calibration performed after each power on or after each LOAD ERROR alarm (no load, load failure, burnt out bulb), if parameter 37 is set to 1 also after alarms: SURGE (Dimmer 2 output overvoltage) and OVERCURRENT (Dimmer 2 output overcurrent)
Range: 0~4
Default: 1
</Help>
<Item label="0" value="0" />
<Item label="1" value="1" />
<Item label="2" value="2" />
<Item label="3" value="3" />
<Item label="4" value="4" />
</Value>
<Value type="short" byteSize="2" index="39" label="Max Power load" min="0" max="350" value="250" setting_type="zwave" fw="">
<Help>
This parameter defines the maximum load for a dimmer.
Range: 0~350
Default: 250
</Help>
</Value>
<Value type="list" byteSize="1" index="40" label="Reaction to General Alarm" min="0" max="3" value="3" setting_type="zwave" fw="">
<Help>
This parameter determines how the device will react to General Alarm frame.
Range: 0~3
Default: 3 (Flash)
</Help>
<Item label="Alarm frame is ignored" value="0" />
<Item label="Turn ON after receiving the alarm frame" value="1" />
<Item label="Turn OFF after receiving the alarm frame" value="2" />
<Item label="Flash after receiving the alarm frame" value="3" />
</Value>
<Value type="list" byteSize="1" index="41" label="Reaction to Flood Alarm" min="0" max="3" value="2" setting_type="zwave" fw="">
<Help>
This parameter determines how the device will react to Flood Alarm frame.
Range: 0~3
Default: 2 (OFF)
</Help>
</Value>
<Value type="list" byteSize="1" index="42" label="Reaction to CO/CO2/Smoke Alarm" min="0" max="3" value="3" setting_type="zwave" fw="">
<Help>
This parameter determines how the device will react to CO, CO2 or Smoke frame.
Range: 0~3
Default: 3 (Flash)
</Help>
</Value>
<Value type="list" byteSize="1" index="43" label="Reaction to Heat Alarm" min="0" max="3" value="1" setting_type="zwave" fw="">
<Help>
This parameter determines how the device will react to Heat Alarm frame.
Range: 0~3
Default: 1 (ON)
</Help>
</Value>
<Value type="byte" byteSize="2" index="44" label="Flashing alarm duration" min="1" max="32000" value="600" setting_type="zwave" fw="">
<Help>
This parameter allows to set duration of flashing alarm mode.
Range: 1~32000 (1s-32000s)
Default: 600 (10 min)
</Help>
</Value>
<Value type="byte" byteSize="1" index="50" label="Active power reports" min="0" max="100" value="10" setting_type="zwave" fw="">
<Help>
The parameter defines the power level change that will result in a new power report being sent. The value is a percentage of the previous report.
Range: 0~100
Default: 10
</Help>
</Value>
<Value type="short" byteSize="2" index="52" label="Periodic active power and energy reports" min="0" max="32767" value="3600" setting_type="zwave" fw="">
<Help>
Parameter 52 defines a time period between consecutive reports. Timer is reset and counted from zero after each report.
Range: 0~32767
Default: 3600
</Help>
</Value>
<Value type="short" byteSize="2" index="53" label="Energy reports" min="0" max="255" value="10" setting_type="zwave" fw="">
<Help>
Energy level change which will result in sending a new energy report.
Range: 0~255
Default: 10
</Help>
</Value>
<Value type="list" byteSize="1" index="54" label="Self-measurement" min="0" max="1" value="0" setting_type="zwave" fw="">
<Help>
The Dimmer 2 may include active power and energy consumed by itself in reports sent to the main controller.
Range: 0~1
Default: 0
</Help>
</Value>
</configuration>
// <Value type="boolean" index="enableDebugging" label="Enable Debug Logging?" value="true" setting_type="preference" fw="3.08">
// <Help>
// </Help>
// </Value>
sorry. been messing about and forgot to set this back. done again. no scenes.
I still have scenes on the 5 I use with scenes.
Noticed that parameter 28 is set to 0 and it should be 1 for scenes
Could you please post the code for the driver?
I noticed that on one iteration of a driver, scenes looked fine, physical switch was fine, but couldn't use software to switch on/off.
And which parameter are you referring to? I can't see any 'numbers'.
Ta!
Ah, 28 seems to be set to one. See post before last.
I've reverted to the RB driver.
Here's the grab:
I can't turn the light on or off.
