I just updated to 2.2.9.129 and some rules were throwing errors and not allowing me to get in to fix because of the same errors. Normally, at this point I would go into Rule Machine restore and revert to older versions, but that functionality wasn't there. I'm reverting to 2.2.8.156. Just wanted to warn others that they might want to wait until things settle.
Edit: Whoops, the reversion is only for the dB. Don't see a way to roll back the hub software. Anyone know how to get rid of a rule that is throwing errors and you cannot delete because when you open it in the editor it also errors?
Edit: I found the clone functionality. It moved to a tab within settings (see below). Still, does anyone know how to force remove a rule when you cannot get to the editor?
Edit: Ok found it. Click the gear icon next to the rule, then scroll to the bottom. I was afraid to click it because it talks about a child instance of rule 5.0 machine. Sounds like it will get rid of all of Rule Machine. May I suggest this be changed to "force delete this rule" or "force delete "?
