[2.2.4.xxx] Is secure inclusion recommended or not for non critical devices?
@bobbyD
Back in V1.1.7 you posted; unless its really required (i.e. locks etc) one would be better off not pairing devices with security.
Is this still the case in 2.2.4?
i really only pair locks and garage opener if i can securly.. and extenders..
i have a couple of light switches and multisensors paired s2 only becuae i was having issues pairing and they seemed to work best that way.
I pair everything S2 that is S2 capable. Why? Dunno, I just do. There is no (appreciable) performance or functionality penalty to go S2 - so why not make it more secure? Not that it matters, but that is the recommended pairing philosophy from SiLabs, too.
That said, when I do an S2 pairing and it decides to just pair non-secure anyway, which happened just this weekend on a device, I don't go back and remove/re-pair it as S2 either. :slight_smile:
I would only do S0 on perimeter security devices (locks, garage door openers) that don't otherwise support S2, as S0 does have a performance penalty.
That's an interesting choice. I personally go out of my way to ensure that no devices are encrypted, unless they must be (locks and garage doors).
the extenders at least the aeon 7's needed to be secure i think in order to run tests to other secure devices and also be able to turn the light on and off? also I believe the ring ver 2 needed to be secure to check for power outages.. and least the one i am using for that?
Just about everything I own (mostly Zooz) always wants to include with S2, and I always just choose whatever the default is when pairing. Is there a performance hit I should worry about with basically my entire mesh included with S2? I have something a bit north of 60 devices...
My Ring Extenders won't pair unless I use S2 Authenticated
In my mind security is an unneeded layer of complexity that if not required should be opted out.
I keep thinking of junior engineers dimensioning a mechanical part. They seem to put the default tolerance to every dimension. When I asked they why they invariably state "...well its the default..". My response is "so consider the following:"
One day a quality engineer comes to you and says a lot of parts were received and a number of them are 0.001 over the tolerance. You say that OK its not a critical dimension. The quality engineer says "well change the drawing if you don't need that tight a tolerance". You say "I can't without customer permission". The quality engineer says "then I will have to reject the lot and we will be out of parts for the scheduled build".
This has happened a number of times that I've been involved in. So this is where I get the inclination to not add complexity unless it is needed. I fully realize the above scenario is quite different that a light on a Hub however it reflects my philosophy.
Sorry for the long post.
I don't know if this reflects your situation or not.
In repairing my WD200+ dimmer w/o security the flow was somewhat unexpected.
  1. Reset the 200+
  2. Start the Hub Z-wave looking for devices, pressed the 200+ top button (initialize discovery)
  3. A device is found and the security window popped up
  4. I selected NO Security pressed OK (or whatever closed the box)
  5. Nothing happened..... waited some more....nothing happened.
  6. I restarted Z-Wave discovery
  7. After a while the 200+ was detected without the securing window popping up.
  8. I saved it and it was joined w/o security.
I would not have expected steps 5 - 8 but it allowed me to pair w/o security. You might give it a try.
The same here. I just don't see any reason to add complexity if I need to later unpair and repair them and have to track down S2 codes and worry about that additional baggage...I've never noticed a performance problem or issue from pairing unsecured.
The only things I pair securely are my garage doors and locks.
