[2.2.4.147 & 148] Rule machine error after trying to import JSON rule [C7]
I receive the following error message when attempting to open Rule Machine (to add a new rule). This happens even after a reboot.
Part of the issue seems to be my attempt to export a rule, modify it and import the changed rule.
The change I attempted to make was to change StatusLed to StatusLED using a text editor.
On trying to import the changed rule I received a message similar to the above. I simply abandon the export / import approach and modified the rule via the UI.
OK, So now I want to add another rule. I receive the above message when just attempting to open the RM app. My guess is the imported JSON file that caused the original is in some cache somewhere and it causing this issue....... or its something else.
Shutdown with pwr off for a few minutes did not clear this error.
I have what I think is the offending JSON file if it might help.
Seriously? This is a very bad idea!!
You will have to restore from backup to get RM to work again.
I understand now, or actually I've learned. Originally I thought changing the case of a word would not be an issue.
