[2.2.4.141]Error Clicking on Z-Wave Details in Settings[C7]
I've noticed long delays and a need to refresh the browser several times while trying to get into the "Z-Wave Details" page.
Tonight, it hung up, I waited a bit, then I got:
Nothing appeared interesting in the "Past Logs" for that. Somehow, bringing up that page is rather hit and miss.
I’ve seen the same.
  1. How many z-wave devices do you have?
  2. Was this encountered soon after restarting the hub, or had the hub been running for awhile?
To be clear, this is NEW, errant behavior. This was not happening more than a couple .xxx releases of 2.2.4 ago (e.g., I didn't notice it on earlier betas).
Normally, this screen appears rather rapidly (just a couple seconds or so). Thus, this isn't due to too many devices making it slow al the time.
I have 67 Z-Wave Devices on that page.
I was seeing hangs prior to the .141 update and after. This latest occurrence with the 500 error, happened after the .141 update--which required a boot within the past few hours.
I had done a complete shutdown, power off, wait, and restart yesterday.
Understood. I noticed (and reported) the 500 error starting in 2.2.4.135
I have only seen it with the first load of the zwave details page and usually within 10-15 minutes after restarting. I figured something during startup was taking some time to complete.
Something seems like it got wonky about .135 or so.
That's about when I started seeing ALL KINDS of things getting bottled up (not regularly--just sporadically). Hopefully, they can sort out what might have changed in that window. :slight_smile:
Fix is coming
Yup it was reported in the beta forums before release. :man_shrugging:
