I'm not sure where in the beta's this may have stopped working but I was writing a new driver and noticed that versionGet isn't working anymore in any of my drivers.
I then loaded the basic z-wave tool which was recently updated by @mike.maxwell and it the versionGet does not respond there either. It did at one point because my driver has the variable set for the version when I initially ran it. Actually, getAssociationReport,getVersionReport an getCommandClassReport don't work in the basic z-wave tool anymore. I tried it on an old device that I used it on before as well as a test and the devices aren't responding with the info. However the getParameterReport does work. I've used this tool when creating a lot of my drivers so I know it did work at some point.
Was anything changed that could have broken these methods in 2.2.3?
I've never gotten the version report to work on non-S2 devices on my C-7. Even worse, at one point Iam sure requesting multiple version reports locked up my zwave (although that was on the very 1st release - not sure it would do that today).
I admit I only tried a few times, though before I moved on to other things.
Hmm.. makes sense. All my devices are using no encryption on my C7. I only noticed it since I was working on another driver.
Thank you. Also I was having issues with the association group methods too. I'm not able to query the association groups for members. Might want to add that to the list as well.
Get Version worked fine with the basic z-wave tool prior to the most current release on a C4 hub. I reported this as a problem with the basic z-wave tool itself, here:
