Trying to add a new button controller tonight and I'm unable to add a rule for double click. Here's what happens:
What driver does the button use? Double Click is not part of the stock button drivers. Only pushed, held and released. The driver would have to support the DoubleTapableButton capability. You can tell right away if it does if there's a double tap button command on the device edit page.
ST built in driver supports doubleTap. I deleted it and re-created and it worked fine if I had it populate all buttons at the beginning.
There's a built in SmartThings Button Driver? What is it listed under?
Samsung Zigbee Button
You know, after I couldn't find it under SM, I looked under SA for Samsung but I guess it must have been staring me in the face. Thanks.
