2.0.1: Table UI layout issues
The DNI column's width is a little bit too much...due to the Nest Presence DNI being a very large string
It's a common strategy that a column grow to accommodate the largest data block. What do you suggest? Wrapping is probably not a good bet, because many ids don't contain spaces. Overflow hidden, perhaps with ellipsis? Not a trivial ask, but doable. I'm just not sure it's worth their effort at this stage.
Either overflow or remove the column. In the current format it’s pretty weird
