Holy cow I’m just looking for 12v color changing bulb lights for my gazebo. You would think they would be a dime a dozen. I have a zen 16 and a 12v power supply to run them. Any ideas?
This is a little unclear, you are wiring in your own, so you don't need any socket type?
Yes. I’m going to run 12v dc in conduit it will have three zones one for each relay. One zone will be deck lights on the rails and the under lighting for the stairs. The second will be strung on the fence and the third will be bulbs strung on the gazebo. I wired a fire tablet 7 to control zen and wall mounted it. I have 8v now through 120v. But it’s not ideal and since I’m running 12v anyway I want to swap them out. The wife likes the color changing. Any thoughts?
Well not a lot of 12v options that I’m aware of.
I know gledopto makes 12v landscape bulbs, so might investigate their line and see if they have something you can use.
Here is one I have for my floodlights.
Gledopto Smart Zigbee Small Voltage 12V 4W RGBCCT MR16 Spotlight 30° Beam Angle Smart Phone App/Voice Control Compatible with Hue Bridge SmartThings Alexa Echo Plus (Require ZigBee Hub) https://smile.amazon.com/dp/B07T2Z2T8L/ref=cm_sw_r_cp_api_glt_fabc_SWFWKX5A2G4MBQZFADBB?_encoding=UTF8&psc=1
Led strips?
I’ll use those under the stairs. But the gazebo has to be the bulb ones or won’t meet code I mean wife will freak out.
If you felt particularly DIY, could buy something like this....
.... and DIY with some IAD-LEDs. That'd be ace.
