I've got all my outdoor garage lights (Z-Wave) on a single group.
At Sunrise, I turn that group off.
3 of the lights go off. 1 does not. I can re-run the rule 2-3 times and eventually it will go back off. Sometimes though, it comes back on.
Is there a way in a rule to do a loop?
do light is on
turn light off
wait 10 seconds
while
Iโm certainly no expert With RM or Private Boolean but Iโd be looking into using PB to do what I think your asking.
You should be able to have a rule set a PB, only when all the lights are On and then check the state of the PB.
You nest rules BUT Iโd be very wary about using loops as they can bring your HE to itโs knees.
Two other things:
have you tried deleting the App or Rule your using and starting afresh ? This has worked for me in the past. Cleaning up my stuff ups.
I did finally get around to doing this last night and for the first time in a long time the light went off this morning. So it MAY be fixed. but it may not. Dunno yet. But all signs are positive.
These lights are a model that are not recognized by hubitat. (Honestly, I forget the make and model) I have them set as Z-Wave Generic Dimmers. I've got 5 of them and they all work fine except in this one rule.
I THINK that problem is that MAYBE the bulb is hooked to 2 Z-Wave controllers. The bulb goes off when the rule runs, but then comes back on at some point.
I do have an old openhab controller that I need to shut down. I'll do that and see if that solves the problem.
