Enough said. We aren't going in this direction, certainly not with respect to CPU, RAM, app consumption, etc. This is not information that we ever look at, it's not helpful or meaningful, and would create more problems and support issues than it would solve.
We will continue to improve error reporting to the Logs, and will continue to improve the Z-Wave implementation wrt issues like ghosts.
Yes, there is. It's custom apps/drivers identification -- that they are present. You have that information already. 90% of our support tickets involve custom drivers and apps. I hope this sheds light on what we're facing. We aren't able to support the debugging of custom software. We've added tools to help you do that, such as the ability to disable any app or driver. If you are having a problem, there are two basic tools: the Logs (where errors are shown --> these reveal bugs, for both built-in and custom code), and disabling custom code to isolate the source of the problem. Logs are the primary tool used by support, and the primary means that engineering has to identify issues.
